for i in range(0,800): arcpy.MakeRasterLayer_management(Mask_Rst,"MaskRst_lyr","Rowid = "+ str(i)) outExtractByMask = ExtractByMask(InRst,"MaskRst_lyr") outExtractByMask.save(OutDir + "\\rst" + str(i))
Could you use ExtractByAttributes(in_raster, where_clause) instead of SelectLayerByAttribute_management(in_layer_or_view, {selection_type}, {where_clause})?
I want to replicate something that I can do within ArcMap and model builder. I have a categorical raster with an attribute table consisting of 10 fields "Rowid", "Value", and "Count". I would like to use the SelectLayerByAttribute_Management tool using arcpy. My code so far is:# Import arcpy moduleimport arcpy# define the location of raster titled rstName Rst = "C:/..../rstName"# Select Rowid = 0arcpy.SelectLayerByAttribute_management(Rst, "NEW_SELECTION", "\"Rowid\" = 0")The error msg I get is:* File "C:\...\abc.py", line 16, in <module>*** arcpy.SelectLayerByAttribute_management(Rst, "NEW_SELECTION", "\"Rowid\" = 0")* File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 4259, in SelectLayerByAttribute*** raise eExecuteError: Failed to execute. Parameters are not valid.ERROR 000840: The value is not a Table View.ERROR 000825: The value is not a layer or table viewERROR 000840: The value is not a Mosaic Layer.Failed to execute (SelectLayerByAttribute).-------------------------Can some help me troubleshoot this issue?
