If I add a createName and createDate through the enable gp tool, the length of the text field for createName is 0 length. Is this expected?
If I disable editor tracking, the disable is still active. enable is active as well. I would expect that before enabling, the enable would be active, and the disable would be inactive. After enabling, the enable would be inactive, and the disable would be active, and then after a disable, the disable should be inactive, with the enable active.
if I enable tracking but forget about creator fields, is there an easy way to add and associate these fields or would the process be to disable, then reenable with these creator fields.Like that if the fields do not exist, they will be created.
