I cannot figure out how to make a field required.
I know that at one point I was able to require a field before the form could be submitted but I cannot find that option now.
Hi Rickey,
In order to create a required field, your feature service will need to have fields where nullable is set to false. You can set fields to be required before publishing your data in ArcMap and ArcGIS Pro.
Let us know how you are publishing your feature service if you need help setting this value.
-Kelly
That is one option I thought would work.
Thank you for your Help!
