ArcGIS Pro 2.6: How to preform left and right Join?
I couldn’t figure out if there is a geoprocessing tool that can perform left and right Join.
For example, in the screenshots below, I wanted to join sheet1 and sheet2 tables to end up with sheet3
Saleh Ahmed
You would have to code a tool using pandas or numpy...
Each table would have to be converted to their appropriate array type, then the join made on a common field.
This can be done with TableToNumPyArray to get the arrays, then when the calculations are done, you can use NumPyArrayToTable to get the resultant back as a table.
Eliminating those steps, the numpy steps can be accomplished as follows. Several join types are demonstrated.
import numpy.lib.recfunctions as rfn a # ---- one table's field 'f0' with a sequence of 10 values array([(0,), (1,), (2,), (3,), (4,), (5,), (6,), (7,), (8,), (9,)], dtype=[('f0', '<i4')]) b # ---- the second table, with a common 'key' field, 'f0' array([(0, 'a'), (1, 'b'), (8, 'c'), (9, 'd')], dtype=[('f0', '<i4'), ('f1', '<U2')]) inner_ = rfn.join_by('f0', a, b, 'inner', usemask=False) outer_ = rfn.join_by('f0', a, b, 'outer', usemask=False) lft_outer_ = rfn.join_by('f0', a, b, 'leftouter', usemask=False) inner_ array([(0, 'a'), (1, 'b'), (8, 'c'), (9, 'd')], dtype=[('f0', '<i4'), ('f1', '<U2')]) outer_ array([(0, 'a'), (1, 'b'), (2, 'N/'), (3, 'N/'), (4, 'N/'), (5, 'N/'), (6, 'N/'), (7, 'N/'), (8, 'c'), (9, 'd')], dtype=[('f0', '<i4'), ('f1', '<U2')]) lft_outer_ array([(0, 'a'), (1, 'b'), (2, 'N/'), (3, 'N/'), (4, 'N/'), (5, 'N/'), (6, 'N/'), (7, 'N/'), (8, 'c'), (9, 'd')], dtype=[('f0', '<i4'), ('f1', '<U2')]) # --- 'N/' is nodata # --- simply send the appropriate array back to Pro using NumPyArrayToTable
Pandas does basically the same thing but just hides numpy functionality underneath.
Thanks Dan.
Unfortunately, I don’t have python knowledge to create an end user tool out the code you have already provided
Hani Draidi
I will put it in my Table tools then, although the demand is low within the Pro environment
https://community.esri.com/people/danretired/blog/2020/05/18/free-tools-for-arcgis-pro-table-tools
Hi Jamal, the FeatureJoiner transformer in Data Interoperability extension has this capability.
FeatureJoiner
Thanks guys.
Right. The tool is there in FME safe. However, I would prefer to have this tool in Pro to keep working as much as possible in the same environment
This could be what you're looking for.
https://github.com/Esri/arcgis-pro-sdk/wiki/ProSnippets-Geodatabase#evaluating-a-querydef-on-a-outer-join
I've successfuly performed an inner join... Working on combining that with an outer join now will let you know how it works out.
Thanks DanielHuantes.
But I have no idea how to create a tool for an end user out of this code
