I am trying to add a hyperlink to a layer referencing another field in the layer. I'm using python3 expression type in the calculate field window. Below is the code:
'https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/!FACILITYID!'
However, It is populating with:
https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/u"00133"
For some reason it is adding the u and the " " around my facility ID
I need it to simply be:
https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/00133
Any help is greatly appreciated!
Try:
r<SPAN class="string token">"url=https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>!FACILITYID!<SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
Thank you both for your help! I used this in the field =
'https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/{}'.format(!FACILITYID!)
If you need a string returned, then you need to concatenate the inputs as strings
r <SPAN class="operator token">=</SPAN> r<SPAN class="string token">"https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/"</SPAN> f <SPAN class="operator token">=</SPAN> <SPAN class="string token">"{}{}"</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>r<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"00133"</SPAN><SPAN class="punctuation token">)</SPAN> f <SPAN class="string token">'https://s3.console.aws.amazon.com/s3/buckets/hamptondes/Manhole/00133'</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
if it is something else, the link is no good, copy the code here if possible.
