What version of Oracle are you using [A.B.C.D notation] Which CPU has been applied?11gWhat version of ArcSDE are you using? [version and service pack, plus any patches]10 without patchHow are the layer's index parameters currently defined? ('sdelayer -o describe_long' outputwill suffice)ArcSDE 10.0 for Oracle11g Build 685 Fri May 14 12:05:43 2010Layer Administration Utility-----------------------------------------------------Layer Description ....: <None>Table Owner ..........: TESTTable Name ...........: CHEMNSpatial Column .......: SHAPELayer Id .............: 183SRID .................: 0Auth SRID.............: 0Minimum Shape Id .....: 1Offset ...............: falsex: -400.000000 falsey: -400.000000System Units .........: 1000000000.000000Z Offset..............: -100000.000000Z Units ..............: 10000.000000Measure Offset .......: <None>Measure Units ........: <None>XY Cluster Tolerance .: 0.000000008983Spatial Index ........: parameter: SPIDX_GRID,GRID0=0.066,FULL exist: Yes array form: 0.066,0,0Layer Envelope .......: minx: -79.49073, miny: 44.99677 maxx: 1083343.00000, maxy: 1354905.00000Entities .............: l+Layer Type ...........: Extended SQL Type/ST_GEOMETRYCreation Date ........: 07/05/11 15:34:26I/O Mode .............: NORMALAutolocking ..........: EnabledPrecision.............: HighUser Privileges ......: SELECT, UPDATE, INSERT, DELETECoordinate System ....: GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]]What is the origin of the data which is being loaded? What tool is being used to load it?I try to import line (MapInfo) to ArcSde. And i use FME Desktop and Server.How many rows exist in the layer before import? How many rows are being added?May be 10000 features.
