# Import system modules import sys, string, os, arcgisscripting # Create the Geoprocessor object gp = arcgisscripting.create(9.3) gp.OverWriteOutput = 1 # Check out Spatial Analyst extension license gp.CheckOutExtension("Spatial") # Parameters Workspace01 = gp.GetParameterAsText(0) gp.AddMessage ("input Workspace01: " + Workspace01) #Workspace01 = r"C:\temp\test\Workspace1" Workspace02 = gp.GetParameterAsText(1) gp.AddMessage ("input Workspace02: " + Workspace02) #Workspace02 = r"C:\temp\test\Workspace2" OutWorkspace = gp.GetParameterAsText(2) gp.AddMessage ("output Workspace: " + output_Workspace) #OutWorkspace = r"C:\temp\test\outputwkspc" try: #Get the raster datasets in the input Workspace01 and loop through them from the start #I removed the messages for easier reading of the code. #Set the environment workspace to workspace one. gp.workspace is an environment variable and must be set befor listing data gp.workspace = Workspace01 InputRasters01 = gp.ListRasters()#This will list all the rasters in Workspace01 gp.workspace = Workspace02#change the workspace to the next workspace you wish to list data for. InputRasters02 = gp.ListRasters() iterInputRasters02 = iter(InputRasters02)#create an iterater for rasters02 so it may be incremented. for InputRaster in InputRasters01:#This will loop through your first list. #Becasue the workspace was changed to create the second list the path to the first list is no longer valid. So the script does not fail #we need to set the full path name to items in InputRasters01. fullInputRaster = Workspace01 + os.sep + InputRaster InputRaster02 = iterInputRasters02.next()#increment #Set the output table name nameRaster1 = gp.describe(fullInputRaster).baseName nameRaster2 = gp.describe(InputRaster02).baseName outRaster = OutWorkspace + os.sep + "mean" + InputRaster + ".tif"#create a tif with first raster name. Use a tif because the name could become too long for esri grid. InExpression = "MEAN(" + fullInputRaster + "," + InputRaster02 +")"#use the variable so the raster is updated for each SOMA call # Process: MapAlgebra gp.SingleOutputMapAlgebra_sa(InExpression, outRaster) except: gp.AddMessage(gp.GetMessages(2)) print gp.GetMessages(2)
