This is probably a pretty simple javascript syntax question but... I successfully ran a relationship query between a polygon layer and table that has multiple matching records. The problem is that I can't figure out how to access each record's attributes. The object returned from the query contains an array of features, so I figured I would just be able to index and select one single feature from the array, but it's not working out that way. I feel like it has something to do with the OBJECTID used in the relationship query, seen at the very top of the tree ("2470"):
What is the syntax for getting at these features/records?
queryableMgmtTractFL<SPAN class="punctuation token">.</SPAN><SPAN class="token function">queryRelatedFeatures</SPAN><SPAN class="punctuation token">(</SPAN>relatedQuery<SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>relatedRecords<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>relatedRecords<SPAN class="punctuation token">[</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">//Doesn't work</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Tried this too:
relatedRecords<SPAN class="punctuation token">.</SPAN>features<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">.</SPAN>attributes<SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
The error message I get is that "features" is undefined.
