you need to apply different projections to different elements of the model - the comp(f){......} function may help you split the model into the various parts.
Ah haa - that'll teach me to look at the pictures and not read properly (actually I'll probably never learn) - I'd try changing the projection to scope.xz
Hi, I'm sure Matthias will respond if there is a better way of doing this but I have found that if you put and extra point in a building edge it will trick CE into drawing that edge as a hip end instead of a gable end so you can create odd-ended roofs like in the picture I attach.[ATTACH=CONFIG]29309[/ATTACH]
