I think that if you search the forums that you will find other users who have (and are) struggling with similar issues.Just brainstorming:Perhaps it is related to inability of ArcGIS Server to find your server. There have been many posts about server having issues with machine names which contain certain characters. Suggest that you use very simple names. Also, you might try using a fully qualified domain name. There have been various issues related to the resolution of machine names.You might try running the SysInternals Process Monitor utility in order to ascertain what the underlying failure is, i.e. what is ArcGIS Server trying to do that is failing. That might give you the insight that you need to be able to understand the problem.When I have problems like this what I try to do is to simplify as much as possible. I might start with a non-domain account and see if that works. Another thing to try is to just use local storage, i.e. not UNC. I understand that these configurations are not what you want to deploy but the goal here is to figure out why it is failing.If you resolve this then please post the resolution. I am hoping that 10.2 has better error messages in these situations.
Does the ArcGIS Server account have the rights needed to log on the machine which is hosting the UNC share?I agree that this should not be needed but perhaps you could add it to see if that is the problem. If you don't control that server then can you do all of this on a test server which you can control?See if there are any NT event log entries on the machine hosting the UNC share.
You could try \\IP address\share\folder.Anything in the NT event log on the server hosting the share?
<Item> <Path>/fileShares/\\host\sharedfolder</Path> <Type>folder</Type> <Info>{"dataStoreConnectionType":"shared","path":"\\\\host\\sharedfolder"}</Info> </Item>
I have ArcGIS Server 10.1 SP1 running on Windows Server 2008. I am trying to register a shared folder using the UNC path as a data store. I've tried this in ArcCatalog 10.1 sp1 and through the web manager interface, and it fails with:Invalid folder location. Unable to access this location.The ArcGIS Server service account is a domain account with full permissions to the share and full NTFS permissions. I've verified this by logging into the ArcGIS server as the service account, opening the UNC path in question, and reading/writing files. The path I'm trying to register is of the form \\server\share\folder. I've also tried just \\server\share, makes no difference.I have an open ticket with ESRI on this, but the tech I'm working with seems to think I haven't applied permissions or I'm mistyping the path. As I stated earlier, I've verified I have the permissions correct and I'm using the correct path. It opens with no problem and that service account has full permissions. I think this may be an issue with ArcGIS Server. Any assistance is appreciated.
I had a similar problem, though my server was in a different domain than the computer with the data. The error was finally resolved by adding a local user to my computer with the data share with the same name and password as the arcgis server account. Perhaps having the arcgis server run under a domain account is the problem, rather than a local account? Also, before finding the solution, I was also able to mount the share,, etc. It was not share permissions, but NTFS permissions that were the problem. The server is trying to view the file using the credentials of your arcgis server account. It makes no sense to me that it works in my case, across domains, simply because I created a local user with the same name and password aas a local user, unless the authentication is skipping SID altogether and just using a name and password. Could you try adding a local user with the same name and password as the domain user on the machine hosting the data?
"Invalid folder location. Unable to access this location."
I agree with William. I was having the same issue, so went into the server that the shared folder is on, created an account for arcgis, and gave it file and share permissions on the shared folder. It worked.
Version 10.2.2
Per a suggestion above, I was trying to use a server with a dash "-" in the server name, copied data to another server and was able to publish.
I faced the same issue on ArcGIS for Server 10.4.1. I had the satellite image (file) on other server and was not able to publish the folder, after reading your i did the following
1. created an identical windows account on the server containing data
but no luck after some investigation and reading from (Make your data accessible to ArcGIS Server—Documentation | ArcGIS Enterprise )
i found that the user must be identical to ArcGIS Server Service Account in user name and Password, then give permissions on the the shared folder to this account, and i was able to register the folder successfully.
Qaisar Nadeem
I have the following case:
The data is stored in machine (m1) and the ArcGIS Server is installed in machine (m2) where these two machines are on the same group.
How the ArcGIS Server User Account in machine m2 can have an access to the D drive of machine m1 (whew the data is stored)?
@DanielLewis ,
Try this, go to properties of the folder > Security > Share and try sharing the folder with Administrators first then try to create the datastore (ArcGIS Server Manger > Site > Data Stores > Register Folder). If it doesn't work, try to share with Everyone. Then register the folder.
I hope that helps.
