Thank you! It seems like the script is running better now. However, I still come back to my first error. ERROR 00728: Field Update does not exist within table... I am not sure why because the two lines before calculating the field were specifically written to create this field...
WARNING 000304: Renamed field Update to Update_ Adding Update_ to sampcells_RotateFeatures...
Can you point me the ESRI web help for the field calculator used in python script.For instance, I never saw this in any help document before: Expression = "'{0}'".format(arcpy.GetParameterAsText(3))
Thanks!!! It works like a charm now!Just for future reference, can you point me the ESRI web help for the field calculator used in python script.For instance, I never saw this in any help document before:
Thanks again
I think your Expression variable should actually be:Expression = '"Update" = ' + "'" + arcpy.GetParameter(3) + "'"
The error is: "cannot concatenate 'str' and 'geoprocessing value object' objects".
# Add Field arcpy.AddMessage("Adding Updated Field...") arcpy.AddField_management(Selected_cnddb_point, UpdatedField, "TEXT", "", "", "50","", "NULLABLE") #Calculate Field arcpy.AddMessage("Calculating Updated Field...") Expression = "'{0}'".format(arcpy.GetParameterAsText(3)) # single quoted string literal arcpy.CalculateField_management(Selected_cnddb_point, UpdatedField, Expression, "PYTHON")
UpdatedField = "Update" Expression = (" = " + "'" + arcpy.GetParameter(3) + "'") arcpy.CalculateField_management(Selected_cnddb_point, UpdatedField, Expression, "PYTHON")
