Good afternoon!
I am trying to create 2D space cubes to visualize the # of COVID-19 daily cases in Puerto Rico by municipalities/counties (78 counties) for over 3+ months.
I was able to create the cubes and unfortunately I am not seeing in the map. I have tried to troubleshoot several times with no luck.
Thanks for you help!!!
looks like there is no coordinate system. If you add it to a map without a basemap, does it show up? or check its properties
Dan,
Good morning!
If I remove or uncheck the basemap the cubes won't show up. When creating the cubes I had to apply a coordinate system of Puerto_Rico_UTM_Zone_20N to define the projection.
The question then becomes... were the coordinates actually in that coordinate system, or was it just defined as such?
