I have an Integromat webhook set up to add data to Google Sheets when a survey is submitted. I am trying to also auto populate a column in Sheets with the image attached to the survey. I have been able to do this and initially the image appears fine, however after a little while, when logging back in to Sheets the image no longer appears. When I try and access the image via its url I get an Invalid Token error message (attached).
Is there any way of resolving this issue so the urls do not break?
Any help would be greatly appreciated.
