Start Time: Wed Sep 07 16:49:39 2011Executing (Select): Select Locations\xyz C:\xyz ""Tags" LIKE '%music%'"
Try:In the expression variable "Tags" LIKE '%String%'This is enough as at the run time the %string% will be replace by the value of the string i.e. musicThis is what you are doing: You are creating a variable for a wild card that you want to use. This variable is of data type string.The name of the variable is String (rename it to something else- xyz and use- "Tags" LIKE '%xyx%')You are substituting the variable name %String%/%xyz% in the expression
