Hi all, I have a Table Frame which is showing some related records. One of the fields I need to show is date of submission, but I cannot seem to hide the Time values (Date field) in my Table Frame in my Layout view. I've disabled Time in the "Configure Attributes" setting at both the Hosted Layer and Web Map levels, but these settings don't seem to persist through when I bring the Web Map into Pro. I see the same thing using either the Table Frame or a single field as Dynamic Text, and I haven't had any luck adjusting this through the dynamic text options yet.
It wouldn't be the end of the world if they weren't showing in UTC time, so if I could fix that then that would help as well...
This is Portal 10.6 with ArcGIS Pro 2.6, so maybe I am limited by that? Thank you for any suggestions.
