Just for clarification, was the original closest facility widget customized for the demo NA service?
Is it correct in stating that if I can alter my settings to match the ones in the demo service then I should be able to get it working?
Hi All,I downloaded Closest Facility Widget for Flex Viewer Application Builder and I am able to import it successfully. It works fine while using sample ESRI Network Service.I tried embedding my Network Service into the widget but it failed. I even tried importing my custom Closest Facility widget which is working fine using Flash Builder but no success.Below is the Error : Input field [sh_name] was not mapped to a field in the network analysis class "Facilities". Input field [DTNAME11] was not mapped to a field in the network analysis class "Facilities". Insufficient number of valid locations in "Facilities" or "Incidents".Where is it actually I am going wrong for my NA service for Application Builder as the same NA service works fine for my customized Flex application.Please help.Thanks,
