'First, need to have an IFeatureWorkspace. Set your a new feature workspace from your existing workspace pFeatureWorkspace = pWorkspace 'Create a new feature layer object Dim pFlayer As New ESRI.ArcGIS.Carto.FeatureLayer 'Set the new object feature class to the open feature class pFlayer.FeatureClass = pFWkSpc.OpenFeatureClass("MyLayerName") 'You can't add a feature class to an IMap object, it has to be a an FDOGraphicsLayer object so... 'Create a new feature dataset object Dim pFeatureDataset As ESRI.ArcGIS.Geodatabase.IFeatureDataset 'set the object to the featurelayer dataset pFeatureDataset = pFlayer.FeatureClass.FeatureDataset 'create new fdographicslayer and fdographicslayerfactory objects Dim pFDOGrLayer As ESRI.ArcGIS.Carto.IFDOGraphicsLayer Dim pFDOGLFactory As ESRI.ArcGIS.Carto.IFDOGraphicsLayerFactory 'The factory must be 'new' pFDOGLFactory = New ESRI.ArcGIS.Carto.FDOGraphicsLayerFactory 'Then set the layer to the factory opengraphicslayer call with the feature workspace, feature dataset, and string name of your layer. pFDOGrLayer = pFDOGLFactory.OpenGraphicsLayer(pFeatureWorkspace, pFeatureDataset, "string name of layer") 'Finally add the fdographicslayer to the map. pMap.AddLayer(pFDOGrLayer)
