I am trying to port over an 10.3.1 script which used the old geometric network functionality in Python scripting. I am running ArcGIS Pro 2.6.2.
In my script, I am creating multiple trace networks to set up a cleaned watercourse network for further hydrology and DEM processing (burning and flow directions etc). It creates the first network (wc_clean_net) to find connected segments (isolated segments are dropped) and enables the network no problem. It also successfully creates a second network (wc_net) in the same dataset (called "Layers") using an upstream trace this time from a particular pour point at the edge of the study area. But when I try to enable the network, I get the following error:
160326: The table already exists.
File "C:\_Workspace\Toolboxes\MNRF_TerrainToolsLocal\Pro\TerrainScripts\Step A.2. Prepare Water_new.py", line 756, in <module>
arcpy.EnableNetworkTopology_tn(wc_net, "", "ENABLE_TOPO")
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\tn.py", line 174, in EnableNetworkTopology
raise e
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\tn.py", line 171, in EnableNetworkTopology
retval = convertArcObjectToPythonObject(gp.EnableNetworkTopology_tn(*gp_fixargs((in_trace_network, max_number_of_errors, only_generate_errors), True)))
File "c:\program files\arcgis\pro\Resources\arcpy\arcpy\geoprocessing\_base.py", line 511, in <lambda>
return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 160326: The table already exists.
Failed to execute (EnableNetworkTopology).
Failed to execute (CreateGeometricNetwork).<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I can enable it manually by running the Toolbox command when I load the network into a map but I can't do it through python.
Below is a sample of the script.
First I try to clean up previous runs of the script deleting the networks before creating them again to help try isolating the problem. I am also checking for "TN_" tables (related to the trace network) that might not be cleaned up properly from previous bailed runs. As a last ditch effort, I tried copying all input feature classes and datasets to a new geodatabase to try running on a 'clean' geodatabase. No luck. Line 58 is where it bails.
<SPAN class="comment token"># Network clean-up from previous runs</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Checking for Networks from previous run..."</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>wc_clean_net<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Deleting 'wc_clean_net'..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>wc_clean_net<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>wc_net<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Deleting 'wc_net'..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>wc_net<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>WC_Clean<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Exists<SPAN class="punctuation token">(</SPAN>wc_select_net<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Deleting 'wc_select_net'..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>wc_select_net<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>WC_Select<SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">#arcpy.env.workspace = Output_Vector_GDB_Workspace</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Workspace = "</SPAN> <SPAN class="operator token">+</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace<SPAN class="punctuation token">)</SPAN>
CurrentLayer <SPAN class="operator token">=</SPAN> <SPAN class="string token">"TN_*"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Checking for '"</SPAN> <SPAN class="operator token">+</SPAN> CurrentLayer <SPAN class="operator token">+</SPAN> <SPAN class="string token">"' orphan Network Tables..."</SPAN><SPAN class="punctuation token">)</SPAN>
GDB_Tables <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListTables<SPAN class="punctuation token">(</SPAN>CurrentLayer<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"All"</SPAN><SPAN class="punctuation token">)</SPAN>
tbl_ctr <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="keyword token">for</SPAN> tbl <SPAN class="keyword token">in</SPAN> GDB_Tables<SPAN class="punctuation token">:</SPAN>
tbl_ctr <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Delete_management<SPAN class="punctuation token">(</SPAN>tbl<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> "</SPAN> <SPAN class="operator token">+</SPAN> str<SPAN class="punctuation token">(</SPAN>tbl_ctr<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">+</SPAN> <SPAN class="string token">" '"</SPAN> <SPAN class="operator token">+</SPAN> CurrentLayer <SPAN class="operator token">+</SPAN> <SPAN class="string token">"' tables deleted."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Performing Connected Trace to create WC Clean layer..."</SPAN><SPAN class="punctuation token">)</SPAN>
WC_Name <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>basename<SPAN class="punctuation token">(</SPAN>WC_Dissolve2<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Dissolved WC Name = '"</SPAN> <SPAN class="operator token">+</SPAN> WC_Name <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Creating Trace Network..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateTraceNetwork_tn<SPAN class="punctuation token">(</SPAN>Layers<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"wc_clean_net"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN>WC_Name<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SIMPLE_EDGE"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Enabling Network..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>EnableNetworkTopology_tn<SPAN class="punctuation token">(</SPAN>wc_clean_net<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ENABLE_TOPO"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Snapping buffer and pour points to network..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Snap_edit<SPAN class="punctuation token">(</SPAN>wc_bf_and_pour_pts<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN>WC_Dissolve2<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"EDGE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"0.1 Meters"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Tracing network..."</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token"># Process: Trace Geometric Network</SPAN>
<SPAN class="comment token">##arcpy.TraceGeometricNetwork_management(wc_clean_net, WC_Selection3, wc_bf_and_pour_pts, "FIND_CONNECTED", "", "", "", "", "", "NO_TRACE_ENDS", "", "", "", "AS_IS", "", "", "", "AS_IS")</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Trace_tn<SPAN class="punctuation token">(</SPAN>wc_clean_net<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"CONNECTED"</SPAN><SPAN class="punctuation token">,</SPAN> wc_bf_and_pour_pts<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"EDGES_ONLY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"AGGREGATED_GEOMETRY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Connected_Network_1"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> wc_traceout<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MultipartToSinglepart_management<SPAN class="punctuation token">(</SPAN>wc_traceout<SPAN class="punctuation token">,</SPAN> WC_Clean<SPAN class="punctuation token">)</SPAN>
wc_clean_lyr <SPAN class="operator token">=</SPAN> <SPAN class="string token">"wc_clean_lyr"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>WC_Clean<SPAN class="punctuation token">,</SPAN> wc_clean_lyr<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Retrieving connected network results..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Layer name is: {0}. Count is: {1}."</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>basename<SPAN class="punctuation token">(</SPAN>WC_Clean<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>wc_clean_lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Performing Upstream Trace to create initial WC Select layer..."</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN>
WC_Name <SPAN class="operator token">=</SPAN> os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>basename<SPAN class="punctuation token">(</SPAN>WC_Clean<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Cleaned WC Name = '"</SPAN> <SPAN class="operator token">+</SPAN> WC_Name <SPAN class="operator token">+</SPAN> <SPAN class="string token">"'"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>CreateTraceNetwork_tn<SPAN class="punctuation token">(</SPAN>Layers<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"wc_net"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN>WC_Name<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"SIMPLE_EDGE"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Network exists... bypassing creation"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>EnableNetworkTopology_tn<SPAN class="punctuation token">(</SPAN>wc_net<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"ENABLE_TOPO"</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Snapping pour points to network..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Snap_edit<SPAN class="punctuation token">(</SPAN>Flags_or_Sources_for_Tracing<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN>WC_Clean<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"EDGE"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"0.1 Meters"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>Trace_tn<SPAN class="punctuation token">(</SPAN>wc_net<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"UPSTREAM"</SPAN><SPAN class="punctuation token">,</SPAN> Flags_or_Sources_for_Tracing<SPAN class="punctuation token">,</SPAN> Barriers_for_Tracing<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"EDGES_ONLY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"AGGREGATED_GEOMETRY"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"NEW_SELECTION"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"Upstream_Network_2"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN> wc_traceout2<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">if</SPAN> Barriers_for_Tracing <SPAN class="operator token">!=</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MultipartToSinglepart_management<SPAN class="punctuation token">(</SPAN>wc_traceout2<SPAN class="punctuation token">,</SPAN> Output_Vector_GDB_Workspace <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> wc_inside<SPAN class="punctuation token">)</SPAN>
wc_inside_lyr <SPAN class="operator token">=</SPAN> <SPAN class="string token">"wc_inside_lyr"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>Output_Vector_GDB_Workspace <SPAN class="operator token">+</SPAN> <SPAN class="string token">"\\"</SPAN> <SPAN class="operator token">+</SPAN> wc_inside<SPAN class="punctuation token">,</SPAN> wc_inside_lyr<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Retrieving upstream 'inside' network results..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Layer name is: {0}. Count is: {1}."</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>wc_inside<SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>wc_inside_lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MultipartToSinglepart_management<SPAN class="punctuation token">(</SPAN>wc_traceout2<SPAN class="punctuation token">,</SPAN> WC_Select<SPAN class="punctuation token">)</SPAN>
wc_select_lyr <SPAN class="operator token">=</SPAN> <SPAN class="string token">"wc_select_lyr"</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>MakeFeatureLayer_management<SPAN class="punctuation token">(</SPAN>WC_Select<SPAN class="punctuation token">,</SPAN> wc_select_lyr<SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Retrieving upstream 'select' network results..."</SPAN><SPAN class="punctuation token">)</SPAN>
arcpy<SPAN class="punctuation token">.</SPAN>AddMessage<SPAN class="punctuation token">(</SPAN><SPAN class="string token">" >> Layer name is: {0}. Count is: {1}."</SPAN><SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN>os<SPAN class="punctuation token">.</SPAN>path<SPAN class="punctuation token">.</SPAN>basename<SPAN class="punctuation token">(</SPAN>WC_Select<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> str<SPAN class="punctuation token">(</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetCount_management<SPAN class="punctuation token">(</SPAN>wc_select_lyr<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>All I can think of is that the Enable function is trying to use the same system table name for the second network that was created for the first network.
Am I missing something or is this a bug?
John
