How do I show the reference grid i.e longitude and latitude coordinates on the map layout ? I am trying to do this in arcgis pro.
then you will have to wait until it is available in PRO, or do the map in ArcMap... read the link, that is why I sent it, it provides a full list of what is NOT available in PRO that IS in ArcMap. Should save you looking around for stuff that doesn't exist yet.
Hi Shaun,
I agree that more pictures in the help would... well, help. Unfortunately, we author the help with an international audience in mind and it can be time-consuming to get images translated if they have text. Also, if the UI changes between releases there could be any number of help images to update and if these get missed - images that are out-of-date.
Tom
Thanks Tom, yes that helped.
I dont know who or where to direct this, but I think it could be very helpful if the help topics, such as the ones you linked to, had more pictures to show where things are/ should look.
Shaun,
It is available. Please refer to the help topic - https://pro.arcgis.com/en/pro-app/help/layouts/grids-and-graticules.htm. Your screenshot shows graticules (in degrees minutes and seconds). So you might be interested in this help topic - https://pro.arcgis.com/en/pro-app/help/layouts/add-and-modify-graticules.htm.
Hope this helps,
I cant figure out if what I am looking for is available or not. I am trying to do the equivalent to this in layout for printing maps:
If it is doable, can someone please direct me to where I set this?
Its been some time since this post. I looked at the link and I'm not sure I understand. I am able to create graticule and measured grids but not referenced grids which is what I need. I need the ability to say look in A1 to find X feature on the map. For now, I'll continue using ArcMap for this. However, this is a feature that Pro needs to eventually have if they want me to stop using ArcMap entirely. I have a list of things that also force me to continue using ArcMap as well but this is just one of them.
I just want to show x and y grid in my final layout and print the map with the grid on.
If you are referring to grids and graticules for layouts, they are not available it is under cartography tools in the big NOT section ...Make Grids and Graticules Layer
