I'm on a time crunch or would read through and find the answer that certainly exist here. I want to join census tract to the excel file attached and nothing I am attempting is working. I did this 3 times with very similar files yesterday and no problem. Ive hit a wall and need some guidance. Thank you for taking the time.
What is the common field between the two? The content and field type need to be the same if you doing a join
I downloaded the Tiger shapefile and added a field to its table Census_Trc (double) calculated based on GEOID. The I added the same field (double) Census_Trc to the Meriden census table but abbreviated the GEOID number using Python script. Thus both have the Census_Trc field. I am not figuring out how to create a matching field on the crime table to base the final join on.
The only way you could use the excel file is to do a spatial join to the census tract polygons?
Wow, It worked but only captured 17/190 records. Just so happens that the Meriden census table has 17 rows. But the data joined matches correctly. Getting closer. Thank you so much. I still dont see how to get the rest but its an improvement. I might need to spit the crime table into sections of 17 rows? Seems convoluted but should work.
