Trying this as a Question instead of a Discussion.
I'm having trouble getting a QueryTable to display. The tool selects a single sewer line, gets the feature ID for the line (called COMPKEY), then uses the ID to build the where clause and hopefully open the query table.
What am I missing?
<SPAN class="keyword token">protected</SPAN> <SPAN class="keyword token">override</SPAN> Task<SPAN class="operator token"><</SPAN><SPAN class="keyword token">bool</SPAN><SPAN class="operator token">></SPAN> <SPAN class="token function">OnSketchCompleteAsync</SPAN><SPAN class="punctuation token">(</SPAN>Geometry geometry<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">{</SPAN>
Uri path <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Uri</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"O:\\P\\A\\T\\H\\CONNECTION.sde"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> QueuedTask<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Run</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN>
ActiveMapView<SPAN class="punctuation token">.</SPAN><SPAN class="token function">SelectFeatures</SPAN><SPAN class="punctuation token">(</SPAN>geometry<SPAN class="punctuation token">,</SPAN> SelectionCombinationMethod<SPAN class="punctuation token">.</SPAN>New<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">string</SPAN> slComp <SPAN class="operator token">=</SPAN> Module1<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCompkey</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN><SPAN class="keyword token">string</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">IsNullOrEmpty</SPAN><SPAN class="punctuation token">(</SPAN>slComp<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="comment token">// Set up Geodatabase Object)</SPAN>
<SPAN class="keyword token">using</SPAN> <SPAN class="punctuation token">(</SPAN>Geodatabase geodatabase <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Geodatabase</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">DatabaseConnectionFile</SPAN><SPAN class="punctuation token">(</SPAN>path<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">string</SPAN> queryString <SPAN class="operator token">=</SPAN> $<SPAN class="string token">"COMPKEY = {slComp}"</SPAN><SPAN class="punctuation token">;</SPAN>
QueryDef queryDef <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryDef</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN>
Tables <SPAN class="operator token">=</SPAN> <SPAN class="string token">"SDE.TABLE.NAME"</SPAN><SPAN class="punctuation token">,</SPAN>
WhereClause <SPAN class="operator token">=</SPAN> queryString<SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN>
QueryTableDescription queryTableDescription <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">QueryTableDescription</SPAN><SPAN class="punctuation token">(</SPAN>queryDef<SPAN class="punctuation token">)</SPAN>
MakeCopy <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
Name <SPAN class="operator token">=</SPAN> $<SPAN class="string token">"Preventive Maintenance: {slComp}."</SPAN><SPAN class="punctuation token">,</SPAN>
PrimaryKeys <SPAN class="operator token">=</SPAN> geodatabase<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetSQLSyntax</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">QualifyColumnName</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"SDE.sewerman.tblV8PMTOOL"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"COMPKEY"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">var</SPAN> queryTable <SPAN class="operator token">=</SPAN> geodatabase<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenQueryTable</SPAN><SPAN class="punctuation token">(</SPAN>queryTableDescription<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">int</SPAN> count <SPAN class="operator token">=</SPAN> queryTable<SPAN class="punctuation token">.</SPAN><SPAN class="token function">GetCount</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>count <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">)</SPAN>
MessageBox<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Show</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Sewer line selected has no preventive maintenance scheduled."</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">else</SPAN>
<SPAN class="comment token">// Used since query table doesn't display</SPAN>
<SPAN class="comment token">// MessageBox.Show($"Row count: {count}");</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
