I want to change the name of a feature class subtype using ArcObjects (subtype code will remain the same). The feature class is part of a geometric network so I don't want to delete and recreate it as it has connectivity rules associated with it. On the ISubtypes interface the Subtypes and SubtypeName properties are read-only.
The name can be changed manually through the interface in ArcCatalog but this is required for a script to progress schema changes through dev, test, prod environments.
It can be achieved through a complete hack of the GDB_ITEMS table using the SQL below but I don't really want to go there.
UPDATE SDE.GDB_ITEMS
SET Definition.modify('replace value of (//DEFeatureClassInfo/Subtypes/Subtype[SubtypeCode=70301]/SubtypeName/text())[1] with ("Inverter Location")')
WHERE NAME = 'Electricity.ArcFM.Inverter'
