import sys sys.path.append(<path to numpy>) import numpy
Hi, all -I've just installed ArcMap 9.3.1 and am trying to use numpy in a Python script called from ArcToolbox, but I get this error: <type 'exceptions.ImportError'>: No module named numpy. I know it's installed, and if I bring up a python shell and "import * from numpy" it works fine.Spatial Statistics tools don't work either, some giving the same numpy error as above, others with variations on this:<type 'exceptions.ImportError'>: Bad magic number in C:\Program Files (x86)\lib\subprocess.pyc. Sometimes the error is for random.pyc. So far I've tried reinstalling just python and numpy, didn't help, nor did reinstalling all of 9.3.1. I made sure that there are no older versions of python on the machine and either deleted or renamed every ArcMap/ESRI directory I could find, in case an old setting was hanging around. I'm starting to think that there's a greater problem, as I tried Arc 10 and it was a nightmare, crashing regularly and with missing libraries (functools when trying to use Raster Calculator), when a colleague running the same OS (Windows XP Professional x64) has had none of the same problems with either 9.3.1 or 10.Any ideas would be greatly appreciated...~ Stacie
Please follow the instructions on the following Web Page:
Create a PYTHONPATH variable
http://mattmakesmaps.com/blog/2013/07/10/fixing-arcgis-10-dot-1-python-console-numpy-import-error/
and this thread is 5 years old
