ArcGIS Enterprise 10.5 installed on OEL 7.2. The serverdiag seems to be OK with the warning of core services not starting. The service-error.log file indicates error in Java below. The service.log seems OK. But the problem is none of the services are starting. We just recognized that the ArcGIS server wasn't working probably for 2-3 days today, so we can not trace back to what the problem might be. I also changed the SERVER TMP in usr/init_user_param.sh but that didn't work also after a server stop and start.
Any suggestions from the below logs of why the services might not be starting?
Service-error.log file contents:
Mar 30, 2017 2:50:23 PM ClientCommunicatorAdmin restart
WARNING: Failed to restart: java.rmi.NoSuchObjectException: no such object in table
WARNING: Failed to restart: java.io.IOException: Failed to get a RMI stub: javax.naming.NameNotFoundException: jmxrmi
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at org.apache.http.conn.scheme.PlainSocketFactory.connectSocket(PlainSocketFactory.java:117)
at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection(DefaultClientConnectionOperator.java:177)
at org.apache.http.impl.conn.ManagedClientConnectionImpl.open(ManagedClientConnectionImpl.java:304)
at org.apache.http.impl.client.DefaultRequestDirector.tryConnect(DefaultRequestDirector.java:611)
at org.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:446)
at org.apache.http.impl.client.AbstractHttpClient.doExecute(AbstractHttpClient.java:863)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:72)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:214)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:160)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:136)
at com.esri.arcgis.discovery.admin.util.HttpUtil.postToURL(HttpUtil.java:405)
at com.esri.arcgis.discovery.admin.util.HttpUtil.postPropsToURL(HttpUtil.java:329)
at com.esri.arcgis.discovery.admin.system.handlers.RestConfigManager$a.call(RestConfigManager$a.java:710)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Service.log file contents (last 100 lines)
JMX Closed
WARNING: Could not connect to Log service. Writing log message to console.
<Msg time="2017-03-30T14:50:23,943" type="WARNING" code="6740" source="Admin" process="14311" thread="1" methodName="" machine="" user="" elapsed="">The machine '10.0.87.21' was not reachable while performing this operation. The server machine will be notified of this change when it comes back online. If ArcGIS Server is going to continue to be unavailable, remove the machine from the site.</Msg>
Start invoked
Thu Mar 30 14:50:33 AZT 2017:Start NodeAgent.start().
Thu Mar 30 14:50:33 AZT 2017:Loading all observers.
arcgis_cloud_platform=null
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'LogServiceObserver'.
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'ServerUninstallObserver'.
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'ServerConfigObserver'.
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'AutomaticMachineRenameObserver'.
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'VerifyMachineRegistrationObserver'.
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'Server upgrader'.
Thu Mar 30 14:50:33 AZT 2017:NodeAgent loaded observer 'PlatformServicesPluginObserver'.
Thu Mar 30 14:50:33 AZT 2017:Regular startup of Server.
Thu Mar 30 14:50:33 AZT 2017:Starting RMI connector for NodeAgent.
Thu Mar 30 14:50:34 AZT 2017:Invoking beforeStart() for all observers.
Thu Mar 30 14:50:34 AZT 2017 JMXServerContoller.getJMXConnector() failed to return connection - Failed to retrieve RMIServer stub: javax.naming.NameNotFoundException: jmxrmi17983:9
Thu Mar 30 14:50:34 AZT 2017:Registering and starting log service on TEKUISPARCGIS01.EMDKDEDRX.GOV.AZ.
Thu Mar 30 14:50:34 AZT 2017:Registering NodeAgent as JMX bean.
Thu Mar 30 14:50:34 AZT 2017:Loading all plugins.
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'ProcessMonitor'.
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'DirectoryCleaner'.
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'UlimitMonitor'.
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'LogFileLimiter'.
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'ConfigSynchronizer'.
Thu Mar 30 14:50:34 AZT 2017:Loading plugin.. com.esri.arcgis.discovery.admin.plugins.ServiceInstanceMonitor
Thu Mar 30 14:50:34 AZT 2017:Props {PeriodicInterval=1, NodeAgentCustomPlugin=false}
Thu Mar 30 14:50:34 AZT 2017:Loaded plugin com.esri.arcgis.discovery.admin.plugins.ServiceInstanceMonitor
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'ServiceInstanceMonitor'.
Thu Mar 30 14:50:34 AZT 2017:NodeAgent loaded plugin 'PlatformServicesPluginObserver'.
Thu Mar 30 14:50:34 AZT 2017:Starting all plugins.arcgis
StartRMID - arg: -J-Djava.security.policy=file:////home/arcgis/server/framework/etc/rmid.policy
StartRMID - arg: -J-Dsun.rmi.activation.execPolicy=com.esri.arcgis.discovery.servicelib.impl.RMIDPolicyChecker
StartRMID - arg: -J-Djava.class.path=/home/arcgis/server/framework/lib/server/arcgis-servicelib.jar:/home/arcgis/server/framework/lib/server/arcgis-common.jar
StartRMID - arg: -J-Djava.rmi.server.useCodebaseOnly=true
StartRMID - arg: -port
StartRMID - arg: 1098
Using GERONIMO_HOME: /home/arcgis/server/geronimo
Using GERONIMO_TMPDIR: var/temp
Using ARCGIS_JAVA_HOME: /home/arcgis/server//framework/runtime/jre
Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=256m; support was removed in 8.0
Booting Geronimo Kernel (in Java 1.8.0_101)...
Starting Geronimo Application Server v2.2.2-SNAPSHOT
[****************************************] 100% 2s Startup complete
Listening on Ports:
4000 0.0.0.0 OpenEJB Daemon
4001 0.0.0.0 JMX Remoting Connector
4002 0.0.0.0 RMI Naming
4003 0.0.0.0 Derby Connector
Started Application Modules:
JAR: com.esri.arcgis.services/GeronimoSingleton/1.0/car
JAR: com.esri.arcgis.services/ServiceCatalog/1.0/car
JAR: com.esri.arcgis.services/System.CachingToolsEx.GPServer/1.0/car
JAR: com.esri.arcgis.services/System.DynamicMappingHost.MapServer/1.0/car
JAR: com.esri.arcgis.services/System.PublishingToolsEx.GPServer/1.0/car
JAR: org.apache.geronimo.configs/mejb/2.2.2-SNAPSHOT/car
RAR: org.apache.geronimo.configs/system-database/2.2.2-SNAPSHOT/car
Geronimo Application Server started
system.reg is not a valid registry file
userdef.reg:4: Mismatched architecture '#arch=win64'
userdef.reg is not a valid registry file
user.reg:4: Mismatched architecture '#arch=win64'
user.reg is not a valid registry file
wine: '/home/arcgis/server/framework/runtime/.wine' is a 32-bit installation, it cannot support 64-bit applications.
