# Open the file FILE = open(output_file, "a") # Write the header (so I can remember what each column is!) FILE.write("name,n,mean_len,total_len,max_len,min_len,stdev_len,mean_closeness,std_closeness,defect_dens,r_score,z_score,p_value\n") # Get the line that I need to write to the CSV file (it is returned from a function I wrote to do my processing) csv_line = process_file(full_path) # Print it to the screen (just for testing really) print csv_line # Write it to the file FILE.write(csv_line + "\n") # Close the file FILE.close()
# Put all of the statistics into a list - in this case all of the items in the list are variables that I have calculated output_stats = [tidied_file_name, n_dunes, mean_len, total_len, max_len, min_len, stdev_len, mean_closeness, std_closeness, defect_dens, r_score, z_score, p_value] # For each of the items in this list, convert it to a string and append to an array for item in output_stats: csv_array.append(str(item)) # Join this array, adding commas between all the items csv_string = ",".join(csv_array) # Return this comma joined array ready to write to the file return csv_string
def writefile(file, list): f = open(file,"w") f.write("EASTING, NORTHING, READING\n") for record in list: f.write("%i, %i, %s\n" % (record[0],record[1],record[2])) f.close() return
