I am creating Python tool box where I am collecting 4 Input raster layer from the user. However I want to check their vertical coordinate system and check whether all the layers have same coordinate system or not.
Other the identifying of the z parameter, you can search the arcpy tree to see if there is anything direct
What is geoprocessing?—Help | ArcGIS for Desktop
I suspect not, so parsing the coordinate system is your only other option
Have you tried collecting the SpatialReference object of the feature class, exporting it to a string and parsing the string representation for the VERTCS? For example, I created some data that uses Web Mercator and MSL_Height vertical system and it's coordinate system string is shown below.
PROJCS['WGS_1984_Web_Mercator_Auxiliary_Sphere',GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Mercator_Auxiliary_Sphere'],PARAMETER['False_Easting',0.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',0.0],PARAMETER['Standard_Parallel_1',0.0],PARAMETER['Auxiliary_Sphere_Type',0.0],UNIT['Meter',1.0]],VERTCS['MSL_Height',VDATUM['Mean_Sea_Level'],PARAMETER['Vertical_Shift',0.0],PARAMETER['Direction',1.0],UNIT['Meter',1.0]];-20037700 -30241100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision
I would assume that most vertical coordinate systems would have these VERTCS and VDATUM tags. If I needed to parse this information I'd just build a regular expression to search for the needed tags or I'd just use python to slice the string to get the portion I need.
Dan Patterson
I have tried with 'hasZPrecision' property of spatial reference object but i am not sure whether it is correct. I want to know the vertical coordinate system is present in raster or not. If yes then is it same with others or not.
What have you tried? You will get better results if you present you stage so far so that people can comment on your code or at least the help file reference topics that you have examined.
