This is the buffer around the current extent that features are retrieved for in OnDemand mode. Features are not retrieved again until either they expire or the map extent changes and is no longer in the buffered extent. Buffer factor can be up to 10. If it is set to 0, every time the map extent is changed a requery will take place in OnDemand mode. If the buffer factor is less than 0, then the layer will never requery from an extent change. This is not usually recommended.
