Hi Salman,
No, you cannot switch the owner of the geodatabase from dbo to sde. You'll need to re-create the geodatabase with the correct option.
-Kim
Hi Jake or Kim,
Can you please help me with my problem? I have created an Enterprise Geodatabase but forget to tick the Sde Owned Schema and it resulted in a dbo owned database. Is it possible to convert or change the owner to sde i.e sde.default ?
""" Name: create_enterprise_gdb.py Description: Provide connection information to a DBMS instance and create an enterprise geodatabase. Type create_enterprise_gdb.py -h or create_enterprise_gdb.py --help for usage Author: Esri """ # Import system modules import arcpy, os, optparse, sys # Define usage and version parser = optparse.OptionParser(usage = "usage: %prog [Options]", version="%prog 1.0 for 10.1 release") #Define help and options parser.add_option ("--DBMS", dest="Database_type", type="choice", choices=['SQLSERVER', 'ORACLE', 'POSTGRESQL', ''], default="", help="Type of enterprise DBMS: SQLSERVER, ORACLE, or POSTGRESQL.") parser.add_option ("-i", dest="Instance", type="string", default="", help="DBMS instance name") parser.add_option ("-D", dest="Database", type="string", default="none", help="Database name: Not required for Oracle") parser.add_option ("--auth", dest="Account_authentication", type ="choice", choices=['DATABASE_AUTH', 'OPERATING_SYSTEM_AUTH'], default='DATABASE_AUTH', help="Authentication type options (case-sensitive): DATABASE_AUTH, OPERATING_SYSTEM_AUTH. Default=DATABASE_AUTH") parser.add_option ("-U", dest="Dbms_admin", type="string", default="", help="DBMS administrator user") parser.add_option ("-P", dest="Dbms_admin_pwd", type="string", default="", help="DBMS administrator password") parser.add_option ("--schema", dest="Schema_type", type="choice", choices=['SDE_SCHEMA', 'DBO_SCHEMA'], default="SDE_SCHEMA", help="Schema Type for SQL Server geodatabase, SDE or DBO. Default=SDE_SCHEMA") parser.add_option ("-u", dest="Gdb_admin", type="string", default="", help="Geodatabase administrator user name") parser.add_option ("-p", dest="Gdb_admin_pwd", type="string", default="", help="Geodatabase administrator password") parser.add_option ("-t", dest="Tablespace", type="string", default="", help="Tablespace name") parser.add_option ("-l", dest="Authorization_file", type="string", default="", help="Full path and name of authorization file") # Check if value entered for option try: (options, args) = parser.parse_args() #Check if no system arguments (options) entered if len(sys.argv) == 1: print "%s: error: %s\n" % (sys.argv[0], "No command options given") parser.print_help() sys.exit(3) #Usage parameters for spatial database connection database_type = options.Database_type.upper() instance = options.Instance database = options.Database.lower() account_authentication = options.Account_authentication.upper() dbms_admin = options.Dbms_admin dbms_admin_pwd = options.Dbms_admin_pwd schema_type = options.Schema_type.upper() gdb_admin = options.Gdb_admin gdb_admin_pwd = options.Gdb_admin_pwd tablespace = options.Tablespace license = options.Authorization_file if (database_type == "SQLSERVER"): database_type = "SQL_SERVER" if( database_type ==""): print " \n%s: error: \n%s\n" % (sys.argv[0], "DBMS type (--DBMS) must be specified.") parser.print_help() sys.exit(3) if (license == ""): print " \n%s: error: \n%s\n" % (sys.argv[0], "Authorization file (-l) must be specified.") parser.print_help() sys.exit(3) if(database_type == "SQL_SERVER"): if(schema_type == "SDE_SCHEMA" and gdb_admin.lower() != "sde"): print "\n%s: error: %s\n" % (sys.argv[0], "To create SDE schema on SQL Server, geodatabase administrator must be SDE.") sys.exit(3) if (schema_type == "DBO_SCHEMA" and gdb_admin != ""): print "\nWarning: %s\n" % ("Ignoring geodatabase administrator specified when creating DBO schema...") if( account_authentication == "DATABASE_AUTH" and dbms_admin == ""): print "\n%s: error: %s\n" % (sys.argv[0], "DBMS administrator must be specified with database authentication") sys.exit(3) if( account_authentication == "OPERATING_SYSTEM_AUTH" and dbms_admin != ""): print "\nWarning: %s\n" % ("Ignoring DBMS administrator specified when using operating system authentication...") else: if (schema_type == "DBO_SCHEMA"): print "\nWarning: %s %s, %s\n" % ("Only SDE schema is supported on", database_type, "switching to SDE schema..." ) if( gdb_admin.lower() == ""): print "\n%s: error: %s\n" % (sys.argv[0], "Geodatabase administrator must be specified.") sys.exit(3) if( gdb_admin.lower() != "sde"): if (database_type == "ORACLE"): print "\nGeodatabase admin user is not SDE, creating user schema geodatabase on Oracle...\n" sys.exit(3) else: print "\n%s: error: %s for %s.\n" % (sys.argv[0], "Geodatabase administrator must be SDE", database_type) sys.exit(3) if( dbms_admin == ""): print "\n%s: error: %s\n" % (sys.argv[0], "DBMS administrator must be specified!") sys.exit(3) if (account_authentication == "OPERATING_SYSTEM_AUTH"): print "Warning: %s %s, %s\n" % ("Only database authentication is supported on", database_type, "switching to database authentication..." ) # Get the current product license product_license=arcpy.ProductInfo() # Checks required license level if product_license.upper() == "ARCVIEW" or product_license.upper() == 'ENGINE': print "\n" + product_license + " license found!" + " Creating an enterprise geodatabase requires an ArcGIS for Desktop Standard or Advanced, ArcGIS Engine with the Geodatabase Update extension, or ArcGIS for Server license." sys.exit("Re-authorize ArcGIS before creating enterprise geodatabase.") else: print "\n" + product_license + " license available! Continuing to create..." arcpy.AddMessage("+++++++++") license = "C:\Program Files\ESRI\License10.1\sysgen\keycodes" print "authorization_file " + license + "\n" try: print "Creating enterprise geodatabase...\n" arcpy.CreateEnterpriseGeodatabase_management(database_platform=database_type,instance_name=instance, database_name=database, account_authentication=account_authentication, database_admin=dbms_admin, database_admin_password=dbms_admin_pwd, sde_schema=schema_type, gdb_admin_name=gdb_admin, gdb_admin_password=gdb_admin_pwd, tablespace_name=tablespace, authorization_file=license) for i in range(arcpy.GetMessageCount()): arcpy.AddReturnMessage(i) arcpy.AddMessage("+++++++++\n") except: for i in range(arcpy.GetMessageCount()): arcpy.AddReturnMessage(i) #Check if no value entered for option except SystemExit as e: if e.code == 2: parser.usage = "" print "\n" parser.print_help() parser.exit(2)
C:\Python27\ArcGISx6410.1>python createArcgisDatabase.py --DBMS=SQLSERVER -i ROM ANPC\ARCGISSQLSERVER -D kostroma -U sa -P 112 -u sde -p 112 -l "C:\Program Files \ESRI\License10.1\sysgen\keycodes" ArcServer license available! Continuing to create... +++++++++ authorization_file C:\Program Files\ESRI\License10.1\sysgen\keycodes Creating enterprise geodatabase... Executing: CreateEnterpriseGeodatabase SQL_Server ROMANPC\ARCGISSQLSERVER kostro ma DATABASE_AUTH sa ***** SDE_SCHEMA sde ***** # "C:\Program Files\ESRI\License1 0.1\sysgen\keycodes" Start Time: Tue Sep 11 12:19:03 2012 User has privileges required to create database objects. Database created. Geodatabase admin user created. Validated authorization file. User has required privileges for geodatabase setup. XML support is enabled for the database instance. Created geodatabase tables and stored procedures. Finished creating geodatabase schema. Succeeded at Tue Sep 11 12:19:34 2012 (Elapsed Time: 31,00 seconds) +++++++++
update sde.sde_versions set name = 'DEFAULT' where version_id = 1
update sde.versions set name = 'DEFAULT' where version_id = 1
