import arcpy mxd = arcpy.mapping.MapDocument(r"C:\Project\Project.mxd") mxd.findAndReplaceWorkspacePaths(r"C:\Project\Data", r"C:\Project\Data2") mxd.saveACopy(r"C:\Project\Project2.mxd") del mxd
I know it's an old post but , I was wondering if there is a way to use this script if my shapefiles are in two different documents?
Yes you would have to run the script on each mxd that has the broken link in it.
fwiw, I have an addin (works with 10.2.x/10.3.x) that can look at all the mxd in a folder (and subfolders), provide a report of all broken links and allow you to update a .csv file and then fix most (if not all) of the broken links). Always do a test on a copy first...but, in case you are interested
Python addin for data inventory and “broken-link” repair.
Not perfect, and may not be work the effort for just two mxd docs...but if yo have a lot, or if machines/paths change, may be worth it.
I'll give it a try, thanks!
