xmlns:usercontrols="clr-namespace:ESRI.ArcGIS.SilverlightMapApp" xmlns:actions="clr-namespace:ESRI.ArcGIS.SilverlightMapApp.Actions"
<UserControl x:Class="Test5.MainPage" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:esri="http://schemas.esri.com/arcgis/client/2009" xmlns:i="http://schemas.microsoft.com/expression/2010/interactivity" xmlns:ei="clr-namespace:Microsoft.Expression.Interactivity.Core;assembly=Microsoft.Expression.Interactions" xmlns:UserControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp" mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="400"> <Grid x:Name="LayoutRoot" Background="White"> <!--Map/Layers--> <esri:Map x:Name="MyMap" WrapAround="True" Extent="-8449438,5093446,-8136352,5276656"> <!--ESRI Street Map--> <esri:ArcGISTiledMapServiceLayer ID="ESRI_Street" Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" /> <!--Constrain the extent--> <i:Interaction.Behaviors> <esri:ConstrainExtentBehavior ConstrainedExtent="-8449438,5093446,-8136352,5276656" /> </i:Interaction.Behaviors> </esri:Map> <!--Top Left Pop Up Menu--> <Grid HorizontalAlignment="Left" VerticalAlignment="Top" Margin="10"> <UserControls:CollapsiblePanel x:Name="MainMenu"> </UserControls:CollapsiblePanel> </Grid> </Grid> </UserControl>
Imports Microsoft.VisualBasic Imports System Imports System.Net Imports System.Windows Imports System.Windows.Controls Imports System.Windows.Documents Imports System.Windows.Ink Imports System.Windows.Input Imports System.Windows.Media Imports System.Windows.Media.Animation Imports System.Windows.Shapes Imports System.Windows.Controls.Primitives Imports ESRI.ArcGIS.Client Imports ESRI.ArcGIS.Client.Map Namespace ESRI.ArcGIS.SilverlightMapApp <TemplateVisualState(GroupName:="ViewStates", Name:="Collapsed")> <TemplateVisualState(GroupName:="ViewStates", Name:="Expanded")> Public Class CollapsiblePanel Inherits Control Public Sub New() Me.DefaultStyleKey = GetType(CollapsiblePanel) End Sub #Region "Dependency Properties" Public Property IsExpanded() Get Return GetValue(IsExpandedProperty) End Get Set(value) SetValue(IsExpandedProperty, value) End Set End Property Public Shared IsExpandedProperty As DependencyProperty = _ DependencyProperty.Register("IsExpanded", GetType(Boolean), GetType(CollapsiblePanel), _ New PropertyMetadata(True, New PropertyChangedCallback(AddressOf OnIsExapandedChanged))) Private Shared Sub OnIsExapandedChanged(ByVal sender As DependencyObject, ByVal e As DependencyPropertyChangedEventArgs) TryCast(sender, CollapsiblePanel).ChangeVisualState(True) End Sub #End Region Public Overrides Sub OnApplyTemplate() MyBase.OnApplyTemplate() ChangeVisualState(False) End Sub Private Sub ChangeVisualState(useTransitions As Boolean) If IsExpanded = True Then VisualStateManager.GoToState(Me, "Expanded", useTransitions) Else VisualStateManager.GoToState(Me, "Collapsed", useTransitions) End If End Sub End Class End Namespace
<ResourceDictionary xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:vsm="clr-namespace:System.Windows;assembly=System.Windows" xmlns:local="clr-namespace:ESRI.ArcGIS.SilverlightMapApp"> <Style TargetType="local:CollapsiblePanel"> <Setter Property="Template"> <Setter.Value> <ControlTemplate TargetType="local:CollapsiblePanel"> <Grid x:Name="LayoutRoot" RenderTransformOrigin="{TemplateBinding RenderTransformOrigin}"> <VisualStateManager.VisualStateGroups> <VisualStateGroup x:Name="ViewStates"> <VisualState x:Name="Expanded"> <Storyboard> <DoubleAnimation BeginTime="00:00:00" Duration="00:00:0.3" Storyboard.TargetName="CollapsiblePanelScale" Storyboard.TargetProperty="ScaleY" To="1" /> <DoubleAnimation BeginTime="00:00:00" Duration="00:00:0.3" Storyboard.TargetName="CollapsiblePanelScale" Storyboard.TargetProperty="ScaleX" To="1" /> <DoubleAnimation BeginTime="00:00:00" Duration="00:00:0.3" Storyboard.TargetName="LayoutRoot" Storyboard.TargetProperty="Opacity" To="1" /> </Storyboard> </VisualState> <VisualState x:Name="Collapsed"> <Storyboard> <DoubleAnimation BeginTime="00:00:00" Duration="00:00:0.2" Storyboard.TargetName="LayoutRoot" Storyboard.TargetProperty="Opacity" To="0" /> <DoubleAnimation BeginTime="00:00:00" Duration="00:00:0.2" Storyboard.TargetName="CollapsiblePanelScale" Storyboard.TargetProperty="ScaleY" To="0" /> <DoubleAnimation BeginTime="00:00:00" Duration="00:00:0.2" Storyboard.TargetName="CollapsiblePanelScale" Storyboard.TargetProperty="ScaleX" To="0" /> </Storyboard> </VisualState> </VisualStateGroup> </VisualStateManager.VisualStateGroups> <ContentPresenter x:Name="Content" VerticalAlignment="{TemplateBinding VerticalContentAlignment}" HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}" Content="{TemplateBinding Content}" Margin="{TemplateBinding Padding}" ContentTemplate="{TemplateBinding ContentTemplate}"> </ContentPresenter> <Grid.RenderTransform> <ScaleTransform x:Name="CollapsiblePanelScale" ScaleX="1" ScaleY="1" /> </Grid.RenderTransform> </Grid> </ControlTemplate> </Setter.Value> </Setter> </Style> </ResourceDictionary>
"Undefined CLR Namespace". The "clr-namespace" URI refers to a namespace 'ESRI.ArcGIS.SilverlightMapApp' that is not included in the assembly.
xmlns:userControls="clr-namespace:Test5.ESRI.ArcGIS.SilverlightMapApp"
xmlns:userControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp"
There is generic.xaml file In standart esri map application template as shown on the picture.
You have to move it to your project on the client side, after inserting the name of your project instead
of the name "ESRIStandardMapApplication1". It is not obvious action, but it is the solution.
