when i try to "Enable Archiving" i got the same error "attribute column not found" ERROR 999999
EnableArchiving: Attribute column not found.
Can someone help me please?
Hi guys, I solved this issue by right-clicking on the layer, click on properties then source, edit the query, remove everything in the query box then double click on the list of tables (The table that you are using), click on validate, once the validate button is disabled then click on next, select the unique identifier field then OK and that should fix it.
This is an old thread but have any of you tried removing all quotes conveniently added by the tool?
#NIM102585 In ArcGIS Desktop 10.2.2, the quotes have to be either removed or modified in the Expression column of the Make Query table tool to run the tool successfully.
I am having the same error. If anyone found resolution to this I'd love to hear it.
Same issue.
In this case I could not join a SQL Server view to a Featureclass in the Map Document.
I had to delete the SQL View from within ArcCatalog rather than a drop and create from within SSMS.
While using "Make Query Table" tool on an ArcSDE feature class(versioned) and an attribute view, the functions fails to execute saying "Attribute column not found". The multi-part identifier SDE featureclass.columnname could not be bound.What I am trying to do is a join between the feature class and table on A.x = B.yA= SDE feature classB = attribute viewx & y are text fields, 20 character long. The error says column x in feature class A cannot be found. If I try the same join from SQL server backend on the same feature class and view it works perfectly.Any idea what is happening on the arc client?Thanks in advance,-Deepti
