<html lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Validate Attributes</title> <!-- include dojo theme --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} </style> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; overflow:hidden; } #leftPane{ overflow:hidden; border:none; color:#5C832F; } #map{ border: solid medium #382513; padding:0; } .esriAttributeInspector{ atiLayerName:'Building Details' } .templatePicker{ border:none !important; } .templatePicker .grid .groupLabel{ display:none; } </style> <!-- specify dojo configuration to parse dijits at load time --> <script type="text/javascript"> dojoConfig = { parseOnLoad:true }; </script> <!-- reference ArcGIS JavaScript API --> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script> <script type="text/javascript"> //require selection dijit dojo.require("esri.map"); dojo.require("esri.dijit.editing.Editor-all"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.form.DateTextBox"); dojo.require("dijit.form.TextBox"); var map; function init() { //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "http://autumn/proxy/proxy.ashx"; //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications. esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var initialExtent = new esri.geometry.Extent({"xmin":-13062820,"ymin":4063755,"xmax":-13048794,"ymax":4071609,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent:initialExtent, slider: false, nav: true }); dojo.connect(map, "onLoad", function() { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); dojo.connect(map, "onLayersAddResult", initEditor); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); //Add the editable feature layer to the map var pointsOfInterest = new esri.layers.FeatureLayer("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Notes/FeatureServer/0",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([pointsOfInterest]); } function initEditor(results) { //only one layer var featureLayer = results[0].layer; //add a default value for newly added features dojo.connect(featureLayer,'onBeforeApplyEdits',function(adds,deletes,updates){ dojo.forEach(adds,function(add){ if(add.attributes['name'] === null){ add.attributes['name'] = 'Sam Wrangler'; } }); }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: [featureLayer], rows: 'auto', groupingEnabled:false, columns: 1 },'editorDiv'); templatePicker.startup(); var textDijit = new dijit.form.TextBox({ id:"nameField", placeHolder:'Enter your name here' //do they need placeholder or value }); var layerInfos = [{ 'featureLayer':featureLayer, 'showAttachments':false, 'showDeleteButton':false, 'fieldInfos':[ {'fieldName':'name','label':'Name','customField':textDijit}, {'fieldName':'email','label':'Email'} ] }]; //define the editor settings var settings = { map: map, templatePicker:templatePicker, layerInfos:layerInfos }; var params = {settings: settings}; //Create the editor widget var editorWidget = new esri.dijit.editing.Editor(params); editorWidget.startup(); //resize the info window (attribute inspector) map.infoWindow.resize(295,245); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'sidebar'" style="width:100%;height:100%;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> <div id="leftPane" data-dojo-type="dijit.layout.ContentPane" style="width:100px;" data-dojo-props="region:'left'"> <div>Click the Notes icon - then click location on map to add new map note. When a new phone number is entered dojo's ValidationTextBox is used to make sure a properly formatted phone number is entered.</div> <div id="editorDiv"></div> <div></div> </div> </div> </body> </html>
Tried to register widget with id==templateDiv but that id is already registered http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6 Line 48
Setting a value on a custom widget probably won't work because when the attribute editor is displayed it will overwrite your value with the value (perhaps null) for the currently edited feature. Here's an example that uses the 'onBeforeApplyEdits' approach. Is there a reason you didn't want to use this approach? <html lang="en"> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9" /> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <title>Validate Attributes</title> <!-- include dojo theme --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.6/js/dojo/dijit/themes/claro/claro.css"> <style type="text/css"> .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} </style> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; overflow:hidden; } #leftPane{ overflow:hidden; border:none; color:#5C832F; } #map{ border: solid medium #382513; padding:0; } .esriAttributeInspector{ atiLayerName:'Building Details' } .templatePicker{ border:none !important; } .templatePicker .grid .groupLabel{ display:none; } </style> <!-- specify dojo configuration to parse dijits at load time --> <script type="text/javascript"> dojoConfig = { parseOnLoad:true }; </script> <!-- reference ArcGIS JavaScript API --> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.6"></script> <script type="text/javascript"> //require selection dijit dojo.require("esri.map"); dojo.require("esri.dijit.editing.Editor-all"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.form.DateTextBox"); dojo.require("dijit.form.TextBox"); var map; function init() { //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "http://autumn/proxy/proxy.ashx"; //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications. esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var initialExtent = new esri.geometry.Extent({"xmin":-13062820,"ymin":4063755,"xmax":-13048794,"ymax":4071609,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent:initialExtent, slider: false, nav: true }); dojo.connect(map, "onLoad", function() { //resize the map when the browser resizes dojo.connect(dijit.byId('map'), 'resize', map,map.resize); }); dojo.connect(map, "onLayersAddResult", initEditor); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); //Add the editable feature layer to the map var pointsOfInterest = new esri.layers.FeatureLayer("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Notes/FeatureServer/0",{ mode: esri.layers.FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); map.addLayers([pointsOfInterest]); } function initEditor(results) { //only one layer var featureLayer = results[0].layer; //add a default value for newly added features dojo.connect(featureLayer,'onBeforeApplyEdits',function(adds,deletes,updates){ dojo.forEach(adds,function(add){ if(add.attributes['name'] === null){ add.attributes['name'] = 'Sam Wrangler'; } }); }); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: [featureLayer], rows: 'auto', groupingEnabled:false, columns: 1 },'editorDiv'); templatePicker.startup(); var textDijit = new dijit.form.TextBox({ id:"nameField", placeHolder:'Enter your name here' //do they need placeholder or value }); var layerInfos = [{ 'featureLayer':featureLayer, 'showAttachments':false, 'showDeleteButton':false, 'fieldInfos':[ {'fieldName':'name','label':'Name','customField':textDijit}, {'fieldName':'email','label':'Email'} ] }]; //define the editor settings var settings = { map: map, templatePicker:templatePicker, layerInfos:layerInfos }; var params = {settings: settings}; //Create the editor widget var editorWidget = new esri.dijit.editing.Editor(params); editorWidget.startup(); //resize the info window (attribute inspector) map.infoWindow.resize(295,245); } dojo.addOnLoad(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'sidebar'" style="width:100%;height:100%;"> <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'"></div> <div id="leftPane" data-dojo-type="dijit.layout.ContentPane" style="width:100px;" data-dojo-props="region:'left'"> <div>Click the Notes icon - then click location on map to add new map note. When a new phone number is entered dojo's ValidationTextBox is used to make sure a properly formatted phone number is entered.</div> <div id="editorDiv"></div> <div></div> </div> </div> </body> </html>
