een bescherming foutmelding krijgen bij het afdrukken vanaf Pro 2.2.12813 naar de HP Design Jet 1055cm<\/SPAN><\/P><\/BODY><\/HTML>
Is this set as your default printer?
Does this occur for all maps/layouts in all aprx files?
Are you able to print to other printers that are connected to this computer?
Hi, thanks for your reply
Not set as the default printer
Happens to all aprx files
Can print to other printers
Can print from ArcMap 10.5 just fine
Can you try setting the HP Design Jet 1055cm as your default printer to see if that at least makes a difference?
Maybe you need to upgrade the drivers used for this printer from the manufacturers website (might want to discuss this option with your IT people).
I'll give that a try and get back to you
