Are you looking for this, or do you mean the hand that's shown while you're panning?http://help.arcgis.com/en/webapi/flex/apiref/com/esri/ags/Map.html#openHandCursorVisible
This seems to be a new Flash Player 10.1 bug that only happens in IE. If a custom cursor is being shown, and you right click, then the system cursor is supposed to be shown, but in FP 10.1 it isn't, so you're left with no cursors. This is happening for 1.x apps too.I've submitted this bug to Adobe at https://bugs.adobe.com/jira/browse/SDK-26818A workaround is to set the wmode to opaque, but only for IE since Chrome will show both cursors otherwise.e.g. In the html template add this after params.allowfullscreen = "true"; if (swfobject.ua.ie && swfobject.ua.win) // http://code.google.com/p/swfobject/wiki/api { params.wmode = "opaque"; // workaround for cursor issue - https://bugs.adobe.com/jira/browse/SDK-26818 }
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:mx="library://ns.adobe.com/flex/mx" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="Basic usage of DrawTool"> <s:layout> <s:VerticalLayout paddingBottom="5"/> </s:layout> <fx:Style> @namespace mx "library://ns.adobe.com/flex/mx"; mx|ToolTip { font-size: 14; } </fx:Style> <fx:Script> <![CDATA[ import com.esri.ags.events.DrawEvent; import com.esri.ags.geometry.MapPoint; import mx.controls.Alert; import com.esri.ags.Graphic; import spark.events.IndexChangeEvent; import com.esri.ags.events.GraphicEvent; private var menuItem:ContextMenuItem = new ContextMenuItem("Remove Me"); private function init(evt:Event):void { myGraphicsLayer.addEventListener(GraphicEvent.GRAPHIC_ADD,addContextMenu); menuItem.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, removeMeMenuItemHandler); navTool.activate(NavigationTool.PAN); } private function removeMeMenuItemHandler(event:ContextMenuEvent):void { var graphic:Graphic = event.contextMenuOwner as Graphic; graphic.dispatchEvent(new Event("removeMe", true)); } private function addContextMenu(evt:Event):void { var gLyr:GraphicsLayer = evt.target as GraphicsLayer; myGraphicsLayer.addEventListener("removeMe", graphicRemoveMeHandler); for each (var g:Graphic in gLyr.graphicProvider) { if (g.contextMenu == null) { var contextMenu:ContextMenu = new ContextMenu(); contextMenu.hideBuiltInItems(); contextMenu.customItems.push(menuItem); if (g.geometry.type.toUpperCase() == "ESRIGEOMETRYPOINT") { var mp:MapPoint = g.geometry as MapPoint; var menuItem2:ContextMenuItem = new ContextMenuItem("X: " + numFormatter2.format(mp.x) + ", Y: " + numFormatter2.format(mp.y)); contextMenu.customItems.push(menuItem2); } g.contextMenu = contextMenu; } } } private function graphicRemoveMeHandler(event:Event):void { var gLyr:GraphicsLayer = event.currentTarget as GraphicsLayer; var graphic:Graphic = event.target as Graphic; var gObj:Object = myGraphicsLayer.graphicProvider; for (var i:int = myGraphicsLayer.numGraphics - 1; i >= 0; i--) { if(myGraphicsLayer.graphicProvider.name == graphic.name) myGraphicsLayer.remove(myGraphicsLayer.graphicProvider); } } protected function bb_changeHandler(event:IndexChangeEvent):void { if (event.newIndex == -1) { drawTool.deactivate(); navTool.activate(NavigationTool.PAN); navTool.deactivate(); } else { switch (bb.dataProvider.getItemAt(event.newIndex)) { case "Point": navTool.deactivate(); drawTool.activate(DrawTool.MAPPOINT); break; case "Multipoint": navTool.deactivate(); drawTool.activate(DrawTool.MULTIPOINT); break; case "Single Line": navTool.deactivate(); drawTool.activate(DrawTool.LINE); break; case "Polyline": navTool.deactivate(); drawTool.activate(DrawTool.POLYLINE); break; case "FreeHand Polyline": navTool.deactivate(); drawTool.activate(DrawTool.FREEHAND_POLYLINE); break; case "Polygon": navTool.deactivate(); drawTool.activate(DrawTool.POLYGON); break; case "Freehand Polygon": navTool.deactivate(); drawTool.activate(DrawTool.FREEHAND_POLYGON); break; case "Rectangle": navTool.deactivate(); drawTool.activate(DrawTool.EXTENT); break; } } } ]]> </fx:Script> <fx:Declarations> <!-- Symbol for all point shapes --> <esri:SimpleMarkerSymbol id="sms" color="0x00FF00" size="12" style="square"/> <!-- Symbol for all line shapes --> <esri:SimpleLineSymbol id="sls" color="0x00FF00" width="3"/> <!-- Symbol for all polygon shapes --> <esri:SimpleFillSymbol id="sfs" color="0xFFFFFF" style="diagonalcross"> <esri:outline> <esri:SimpleLineSymbol color="0x00FF00" width="2"/> </esri:outline> </esri:SimpleFillSymbol> <esri:DrawTool id="drawTool" fillSymbol="{sfs}" graphicsLayer="{myGraphicsLayer}" lineSymbol="{sls}" map="{myMap}" markerSymbol="{sms}"/> <mx:NumberFormatter id="numFormatter" useThousandsSeparator="true" precision="2"/> <mx:NumberFormatter id="numFormatter2" useThousandsSeparator="false" precision="2"/> <esri:NavigationTool id="navTool" map="{myMap}" /> </fx:Declarations> <s:controlBarLayout> <s:HorizontalLayout horizontalAlign="center" paddingBottom="7" paddingTop="7"/> </s:controlBarLayout> <s:controlBarContent> <s:ButtonBar id="bb" change="bb_changeHandler(event)"> <s:ArrayList> <fx:String>Point</fx:String> <fx:String>Multipoint</fx:String> <fx:String>Single Line</fx:String> <fx:String>Polyline</fx:String> <fx:String>FreeHand Polyline</fx:String> <fx:String>Polygon</fx:String> <fx:String>Freehand Polygon</fx:String> <fx:String>Rectangle</fx:String> </s:ArrayList> </s:ButtonBar> </s:controlBarContent> <esri:Map id="myMap" level="3" useHandCursor="true"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"/> <esri:GraphicsLayer id="myGraphicsLayer" creationComplete="init(event)"/> </esri:Map> <s:Label text="The DrawTool can be used to draw new features which can then either be used as input for another task or saved as new features in a feature service (using the FeatureLayer.applyEdits)" width="100%"/> </s:Application>
Are you able to reproduce this issue in the Sample?http://help.arcgis.com/en/webapi/flex/samples/index.html?sample=NavigationToolsIf not, can you post a test case?
Tony, OK glad to see that I am not the only one noticing that issue. It is not limited to the pan mode though. No matter what tool or cursor is set when you right click and hover over a context menu the mouse cursor is completely gone until you dismiss that context menu.
