Log Name: ApplicationSource: SideBySideDate: 8/13/2013 8:04:26 AMEvent ID: 33Task Category: NoneLevel: ErrorKeywords: ClassicUser: N/AComputer: <HOSTNAME>.<DOMAIN>Description:Activation context generation failed for "C:\Program Files\Common Files\ArcGIS\bin\SoftwareAuthorization.exe". Dependent Assembly Microsoft.VC90.CRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8" could not be found. Please use sxstrace.exe for detailed diagnosis.Event Xml:<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="SideBySide" /> <EventID Qualifiers="49409">33</EventID> <Level>2</Level> <Task>0</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2013-08-13T14:04:26.000000000Z" /> <EventRecordID>1639</EventRecordID> <Channel>Application</Channel> <Computer><HOSTNAME>.<DOMAIN></Computer> <Security /> </System> <EventData> <Data>Microsoft.VC90.CRT,processorArchitecture="amd64",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.21022.8"</Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data>C:\Program Files\Common Files\ArcGIS\bin\SoftwareAuthorization.exe</Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> <Data> </Data> </EventData></Event>
SideBySide errors are typically caused by the current Microsoft Visual C++ version not being backward compatible with the application that failed. The Event ID 33 error message is typically: Activation context generation failed for �??program name�?�..Please use sxstrace.exe for detailed diagnosis. There are other similar SideBySide errors with the same problem of backward compatibility. If the software works OK then you don't have to fix it but if it does not or you want to get rid of this error here are two Fixes:1) Reinstall or Repair (preferred if an option) the application. Often the installation package will have the version of Microsoft Visual C++ that it uses and will install it.2) Try to figure out what Microsoft Visual C++ Redistributable Package version (available versions are: 2003, 2005, 2008, & 2010) the application needs (most likely the one that came out prior to the date that the application software was created; check the dates of the files in the package). . These are available through Microsoft's Downloads.Worse comes to worse you can just try installing a previous version to see if it works, if not then try the one before that. Though I don't like it, you can have multiple versions of Microsoft on your computer and most people do because various install programs will install the one that they like.
Error message: "Side-by-side configuration is incorrect"The machine is missing the correct C++ runtime components for your type of system. (x86 or x64).Installing the following update resolved the issue.Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) http://www.microsoft.com/downloads/en/details.aspx?familyid=A5C84275-3B97-4AB7-A40D-3802B2AF5FC2&displaylang=enMicrosoft Visual C++ 2008 SP1 Redistributable Package for (x64)http://www.microsoft.com/downloads/en/details.aspx?familyid=BA9257CA-337F-4B40-8C14-157CFDFFEE4E&displaylang=enMicrosoftVisual C++ 2010 Redistributable Package (x86) http://www.microsoft.com/downloads/en/details.aspx?FamilyID=a7b7a05e-6de6-4d3a-a423-37bf0912db84MicrosoftVisual C++ 2010 Redistributable Package (x64) http://www.microsoft.com/downloads/en/details.aspx?FamilyID=bd512d9e-43c8-4655-81bf-9350143d5867Thanks,
