I want to join a layer in ArcServer to a layer in another DB (that part's easy). Then do an UPDATE [attribute x] where table1.ID=table2.ID kind of thing. Merge won't allow a table. Thanks in advance!
Are you using sde? If so what about using a database tool (we use TOAD) and just modify the table outside of Arc. It is safe as long as your tables are not versioned or if they have no add/delete tables. Or you could use arcpy with ArcSDESQLExecute and do the same thing.
Is it a one to one relationship? If so you could use a temporary join to do what you want. SInce I don't know how the table you want want to attribute is defined, you may need to add a field (or more) to hold the data you need.
I am trying to do it from SQL Management Studio now which is the same, functionally, as TOAD. My tables are registered as versioned tho so they are editable. Why is that a problem?
I can do a join, but that won't allow me to do a bulk UPDATE operation.
I'm not sure that SSM is the tool to use with a versioned database; you may run into some problems with that.
Hi Joanna,
You can edit your versioned data via SQL in SSMS. Please read all the following documentation that we have on it and you should be able to edit the data. I am not sure about the joined table.
An overview of editing versioned data using SQL—Help | ArcGIS for Desktop
What type of data can be edited using SQL?—Help | ArcGIS for Desktop
SQL and enterprise geodatabases—Help | ArcGIS for Desktop
Hope this helps!
https://community.esri.com/groups/geodatabase?sr=search&searchId=3ebee0eb-3ced-4a93-a964-841333f41602&searchIndex=0 https://community.esri.com/community/gis/enterprise-gis?sr=search&searchId=001d18c8-f20c-41bb-9bc3-96645f430ff9&searchIndex=1
