<esri:FeatureLayer ID="MG_PrecinctsClassBreak" Url="http://gis.logis.org/arcgis/rest/services/MG_Test/MapServer/6" Renderer="{StaticResource MyClassBreaksRenderer}" OutFields="PRECINCTS_" />
<esri:SimpleFillSymbol x:Key="MyYellowFillSymbol" Fill="#44FFFF00" BorderBrush="Transparent" BorderThickness="2" /> <esri:SimpleFillSymbol x:Key="MyRedFillSymbol" Fill="#44FF0000" BorderBrush="Transparent" BorderThickness="2" /> <esri:SimpleFillSymbol x:Key="MyBlueFillSymbol" Fill="Blue" BorderBrush="Transparent" BorderThickness="2" /> <esri:ClassBreaksRenderer x:Key="MyClassBreaksRenderer" Attribute="PRECINCTS_" DefaultSymbol="{StaticResource MyRedFillSymbol}"> <esri:ClassBreaksRenderer.Classes> <esri:ClassBreakInfo MinimumValue="0.0000" MaximumValue="8.0000" Symbol="{StaticResource MyYellowFillSymbol}" /> <esri:ClassBreakInfo MinimumValue="8.0001" MaximumValue="15.0000" Symbol="{StaticResource MyRedFillSymbol}" /> <esri:ClassBreakInfo MinimumValue="15.0001" MaximumValue="50.0000" Symbol="{StaticResource MyBlueFillSymbol}" /> </esri:ClassBreaksRenderer.Classes> </esri:ClassBreaksRenderer>
selectedGraphic.Symbol = TryCast(LayoutRoot.Resources("StrobeMarkerSymbol_Blue"), ESRI.ArcGIS.Client.Symbols.Symbol)
<!-- UNIQUE VALUE RENDERER --> <esri:SimpleMarkerSymbol x:Key="BLUEMarkerSymbol" Color="Blue" Size="12" Style="Circle" /> <esri:SimpleMarkerSymbol x:Key="PURPLEMarkerSymbol" Color="Purple" Size="12" Style="Circle" /> <esri:UniqueValueRenderer x:Key="MyUniqueValueRenderer" Attribute="TYPE" DefaultSymbol="{StaticResource BLUEMarkerSymbol}"> <esri:UniqueValueRenderer.Infos> <esri:UniqueValueInfo Value="Church" Symbol="{StaticResource PURPLEMarkerSymbol}" /> <esri:UniqueValueInfo Value="SCHOOL" Symbol="{StaticResource PURPLEMarkerSymbol}" /> </esri:UniqueValueRenderer.Infos> </esri:UniqueValueRenderer> <esri:GraphicsLayer ID="MyGraphicsLayerBufferResults" MouseEnter="imageBuffer_Mousehover" MouseLeftButtonDown="GraphicsLayerBuffer_MouseLeftButtonDown" Renderer="MyUniqueValueRenderer" > <esri:GraphicsLayer.MapTip> <Border esri:GraphicsLayer.MapTipHideDelay="00:00:01.5" CornerRadius="10" BorderBrush="#FF222957" BorderThickness="3" Margin="0,0,15,15"> <Border.Background> <LinearGradientBrush EndPoint="1.038,1.136" StartPoint="0.015,0.188"> <GradientStop Color="#FFD1DFF2"/> <GradientStop Color="#FF092959" Offset="0.946"/> </LinearGradientBrush> </Border.Background> <Border.Effect> <DropShadowEffect ShadowDepth="10" BlurRadius="14" Direction="300" /> </Border.Effect> <StackPanel Orientation="Vertical"> <StackPanel Orientation="Horizontal"> <TextBlock Text="Distance: " FontWeight="Bold" HorizontalAlignment="Left" VerticalAlignment="Bottom" /> <TextBlock Text="{Binding [BUFFER_DISTANCE]}" HorizontalAlignment="Left" VerticalAlignment="Center" /> <TextBlock Text=" meters from parcel" HorizontalAlignment="Left" VerticalAlignment="Bottom" /> </StackPanel> </StackPanel> </Border> </esri:GraphicsLayer.MapTip> </esri:GraphicsLayer>
Private Sub QueryTask_ExecuteCompletedBuffer2(ByVal sender As Object, ByVal args As QueryEventArgs) Dim featureSet As FeatureSet = args.FeatureSet If args.FeatureSet.Features.Count < 1 Then MessageBox.Show("No features found") Return End If For Each selectedGraphic As Graphic In args.FeatureSet.Features ' Commented out ' selectedGraphic.Symbol = TryCast(LayoutRoot.Resources("StrobeMarkerSymbol_Blue"), ESRI.ArcGIS.Client.Symbols.Symbol) _resultsGraphicsLayer.Graphics.Add(selectedGraphic) Next selectedGraphic
<esri:UniqueValueRenderer x:Key="MyUniqueValueRenderer" Attribute="TYPE" DefaultSymbol="{StaticResource BLUEMarkerSymbol}"> <esri:UniqueValueRenderer.Infos> <esri:UniqueValueInfo Value="Church" Symbol="{StaticResource BLUEMarkerSymbol}" /> <esri:UniqueValueInfo Value="SCHOOL" Symbol="{StaticResource PURPLEMarkerSymbol}" /> </esri:UniqueValueRenderer.Infos> </esri:UniqueValueRenderer>
I suggest you add a default symbol to your unique value renderer, so we will know if the issue is coming from the values of your attribute 'TYPE'.
<esri:SimpleMarkerSymbol x:Key="BLUEMarkerSymbol" Color="Blue" Size="12" Style="Circle" /> <esri:SimpleMarkerSymbol x:Key="PURPLEMarkerSymbol" Color="Purple" Size="12" Style="Circle" /> <esri:UniqueValueRenderer x:Key="MyUniqueValueRenderer" Attribute="TYPE" DefaultSymbol="BLUEMarkerSymbol" > <esri:UniqueValueRenderer.Infos> <esri:UniqueValueInfo Value="Church" Symbol="{StaticResource PURPLEMarkerSymbol}" /> <esri:UniqueValueInfo Value="SCHOOL" Symbol="{StaticResource PURPLEMarkerSymbol}" /> </esri:UniqueValueRenderer.Infos> </esri:UniqueValueRenderer>
<Grid x:Name="LayoutRoot" Background="{StaticResource BaseColor}"> <Grid.Resources> <esri:SimpleMarkerSymbol x:Key="BLUEMarkerSymbol" Color="Blue" Size="12" Style="Circle" /> <esri:SimpleMarkerSymbol x:Key="PURPLEMarkerSymbol" Color="Purple" Size="12" Style="Circle" /> <esri:UniqueValueRenderer x:Key="MyUniqueValueRenderer" Attribute="TYPE" > <esri:UniqueValueRenderer.Infos> <esri:UniqueValueInfo Value="Church" Symbol="{StaticResource BLUEMarkerSymbol}" /> <esri:UniqueValueInfo Value="SCHOOL" Symbol="{StaticResource PURPLEMarkerSymbol}" /> </esri:UniqueValueRenderer.Infos> </esri:UniqueValueRenderer> </Grid.Resources> <Grid Grid.Row="2"> </esri:Map.Extent> <esri:Map.Layers> <esri:GraphicsLayer ID="MyGraphicsLayerBufferResults" MouseEnter="imageBuffer_Mousehover" MouseLeftButtonDown="GraphicsLayerBuffer_MouseLeftButtonDown" Renderer="MyUniqueValueRenderer" > </esri:Map.Layers> </esri:Map>
_resultsGraphicsLayer = TryCast(MyMap.Layers("MyGraphicsLayerBufferResults"), GraphicsLayer) If args.FeatureSet.Features.Count < 1 Then MessageBox.Show("No features found") Return End If For Each selectedGraphic As Graphic In args.FeatureSet.Features _resultsGraphicsLayer.Graphics.Add(selectedGraphic) Next selectedGraphic
I also noticed that the Renderer is workign on a Feature Layer....I have a grpahics layerTHINK I AM HAVING issues because its a graphics layer....Can I even do this on a graphics layer?
Do I have to set this up in VB?
<esri:FeatureLayer ID="MyFeatureLayerClassBreak" Url="http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/0" Where="STATE_NAME in ('New Mexico', 'Arizona', 'Texas')" Renderer="{StaticResource MyClassBreaksRenderer}" OutFields="POP1990" />
<esri:GraphicsLayer ID="MyGraphicsLayerListBox1" MouseLeftButtonDown="GraphicsLayer_MouseLeftButtonDown" MouseEnter="imageList1_Mousehover" Visible="False" />
For Each selectedGraphic As Graphic In args.FeatureSet.Features selectedGraphic.Symbol = TryCast(LayoutRoot.Resources("StrobeMarkerSymbol_Blue"), ESRI.ArcGIS.Client.Symbols.Symbol) 'selectedGraphic.Symbol = TryCast(LayoutRoot.Resources("MyUniqueValueRenderer"), ESRI.ArcGIS.Client.Symbols.Symbol) _resultsGraphicsLayer.Graphics.Add(selectedGraphic) Next selectedGraphic
That possible or wise?Code:<esri:UniqueValueInfo Value="Arizona" Source="/Assets/images/PushPin3.png"/>Code:<esri:UniqueValueInfo Value="Arizona" Symbol="{SOME ESRI SYMBOL}" />
<esri:UniqueValueInfo Value="Arizona" Symbol="{StaticResource MyRedFillSymbol}" />
