See attached screenshot (first one below). I see ArcGIS.framework there but not samples. Under ArcGIS.framework there are 3 aliases but they are all "broken" - double-clicking on one gives error "The operation can't be completed because the original item for 'ArcGIS' can't be found."
Note: I am still somewhat new to macs, and am not totally clear on the relationship between these folders (i.e., /Library vs. ${HOME}/Library)
See attached screenshot (second one below) - another mac/Xcode detail I am a little unclear on. The value /Users/myuserid/Library/SDKs/** is what displays on the Build Settings page, but if you double-click to edit it shows value $HOME/Library/SDKs. I assume this is OK/correct - just slightly confusing why it shows two different ways.
v2.2.1This update contains a minor fix to the SDK installation package. The installer was unnecessarily laying down files related to legacy XCode Project Templates. These templates were deprecated and removed back at v2.1. In majority of the cases, the template files did not cause any harm. However, in exceptional cases, users were not able to install v2.2 due to permission issues related to where the files were being written. The v2.2.1 installer does not lay down these files.
1. The Esri Help/documentation does not say whether prior versions of the SDK should be uninstalled before installing a new version or not. It'd be helpful if the documentation clarified this point.
2. The Online documentation topic "Configuring an Xcode Project" says to add the following compiler linker flags: "-ObjC -all_load -framework ArcGIS". But the samples also include the additional flag "-lstdc++". Is the latter required? Small detail I know, but the documentation and samples are not consistent here.
User is an administrator is not the reason of this. Let's diagnose the issue. Please follow below steps and send the information.1. Open Terminal and type command, 'echo $HOME' (without quotes). Send the output.2. Open /Application/Utilities/Console >> Click 'Clear Display'.3. Now install the SDK, you'll see the install logs in the Console display.4. Send us the log information. 5. Since, the SDK is getting installed at /Library, you'll see a AGSiOSSDK folder under /Library/Application Support. Please give manifest file from that folder.Regards,Nimesh
