import arcpy import pythonaddins class ButtonClass1(object): """Implementation for TirolerV02_addin.btn1 (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): # Starts Hailtool Dialog print "Hailtool started" pythonaddins.GPToolDialog("C:\\BW_Workspace\\Toolbox_BW_V02\\Toolbox_BW.tbx", "HagelSchadensableitung") class ButtonClass2(object): """Implementation for TirolerV02_addin.btn2 (Button)""" def __init__(self): self.enabled = True self.checked = False def onClick(self): print "hi" pass class ToolClass1(object): """Implementation for TirolerV02_addin.tool1 (Tool)""" def __init__(self): self.enabled = True self.cursors = 3 self.shape = 'Rectangle' def onRectangle(self, rectangle_geometry): """Occurs when the rectangle is drawn and the mouse button is released. The rectangle is a extent object.""" extent = rectangle_geometry # Create a fishnet with 10 rows and 10 columns. if arcpy.Exists(r'in_memory\fishnet'): arcpy.Delete_management(r'in_memory\fishnet') fishnet = arcpy.CreateFishnet_management(r'in_memory\fishnet', '%f %f' %(extent.XMin, extent.YMin), '%f %f' %(extent.XMin, extent.YMax), 0, 0, 10, 10, '%f %f' %(extent.XMax, extent.YMax),'NO_LABELS', '%f %f %f %f' %(extent.XMin, extent.YMin, extent.XMax, extent.YMax), 'POLYGON') arcpy.RefreshActiveView() return fishnet
