Timothy,This is a very common question Image Service verses Image Cache. The answer very much depends on your final product. If it is a static image back drop then cache is faster but if image processing is required then image services are better. For a good discussion on this topic see the following blog http://blogs.esri.com/esri/arcgis/2010/05/04/imagery-in-web-applications-should-i-use-a-cached-map-service-or-an-image-service/In either case I can say you should use a mosaic dataset it will display the image faster in ArcMap than you currently see it displaying. You only need image extension to serve the mosaic dataset. However there is a tool at 10.1 which converts an image service to cache which you will also find useful.RegardsGordon
