I am getting a 404 error when I try to create an event on my initiative. I'm not sure if something got messed up with the data file but I haven't found a way to repair it or reset it.
Are you able to clone the site and use the clone instead once it is setup with the same content (note - custom domains can transfer instantly because you already have an HTTPS certificate on the current site)? If not, I can probably repair it manually but will need to be invited to your organization. This is something we should clean up automatically...apologies that we don't.
Okay. Seems to have worked. We will "flip" the custom domain switch once we are comfortable everything is there.
It is. I'm investigating this further and it looks like there is a Hub application but not a Hub Initiative.
Forward SGF is the custom domain
This will also get you there. Thanks Graham.
https://springfield-comp-plan-hlplanning.opendata.arcgis.com
Is it public - can you send us a URL?
