import os, fnmatch # function to find files with wildcard def find(pattern, path): theFiles = [] for path, dirs, files in os.walk(path): for filename in files: if fnmatch.fnmatch(filename, pattern): theFiles.append(os.path.abspath(os.path.join(path, filename))) return sorted(theFiles) class ToolValidator: """Class for validating a tool's parameter values and controlling the behavior of the tool's dialog.""" def __init__(self): """Setup arcpy and the list of tool parameters.""" import arcpy self.params = arcpy.GetParameterInfo() def initializeParameters(self): """Refine the properties of a tool's parameters. This method is called when the tool is opened.""" return def updateParameters(self): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parmater has been changed.""" # Path to SQL Databases sde_loc = r'\\arcserver1\SDE' sde_db = find('*.mdf', sde_loc) # drop down lists self.params[0].filter.list = [os.path.basename(s).split('.')[0] for s in sde_db] self.params[2].filter.list = ['DBO.DEFAULT', 'DBO.EDITOR'] return def updateMessages(self): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return
