see here http://resources.arcgis.com/en/help/main/10.1/0154/01540000030s000000.htm
abrown31,Did you find the answer to which outboard ports does ArcGIS Desktop use to contact ArcGIS Server? We are in a similar situation needing to cross multiple networks (DMZs). We can connect to ArcGIS Server using ArcGIS Desktop, but cannot publish to it. Error message says "unable to establish connection to the server." My PC cannot ping the ArcGIS Server.
Yes, we use secure services with SSL enabled. I'm connecting using the Primary Site Admin account, so I know it has permission to publish. But I will double check to make sure the ArcGIS Server services account has write permission to all the necessary folders. I think you are on the right track about "allowed admin access by IP" located here:https://servername:6443/arcgis/admin/security/config/updateI've seen another forum where this was the fix to publishing problems. We don't have fixed IPs on our PCs, but I will investigate what can be done.
yes, I've tried to create a service def file and create the map service through Manager. Same error messages. I'm connecting to a SQL Server database which is registered with ArcGIS Server - and the connection is validated. I've also tried copying the data to the server, same error messages.
