Is it possible to customize source codes in story maps in ArcGIS Online Assistant JSON editing or is it must thru own hosted app? Please advise. Thank you!
Hi Alexis -- No you cannot edit the source code of an application through ArcGIS Online Assistant, you can only edit the story configuration. See this article for more information.
If I want to customize story app such as add features in source code to index html story map, is this the only way to this link below and cannot use ArcGIS Online Assistant? https://developerscorner.storymaps.arcgis.com/an-introduction-to-hosting-your-own-story-map-e2450181ad2f
Yes, that's correct.
