I want to retrieve the records having a text inside the feature class irrespective of field name using Arcobjects.
Simply loop all fields of all records from your table:
IEnumerable<SPAN class="operator token"><</SPAN>IFeature<SPAN class="operator token">></SPAN> <SPAN class="token function">GetFeaturesBySearchValue</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">object</SPAN> searchValue<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> featureClass <SPAN class="operator token">=</SPAN> myWorkspace<SPAN class="punctuation token">.</SPAN><SPAN class="token function">OpenFeatureClass</SPAN><SPAN class="punctuation token">(</SPAN>fcName<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> cursor <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN><SPAN class="token function">Search</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> fields <SPAN class="operator token">=</SPAN> featureClass<SPAN class="punctuation token">.</SPAN>Fields<SPAN class="punctuation token">;</SPAN> IFeature feature<SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">while</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>feature <SPAN class="operator token">=</SPAN> cursor<SPAN class="punctuation token">.</SPAN><SPAN class="token function">NextFeature</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">!=</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">int</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><=</SPAN> fields<SPAN class="punctuation token">.</SPAN>FieldCount <SPAN class="operator token">-</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> theValue <SPAN class="operator token">=</SPAN> feature<SPAN class="punctuation token">.</SPAN><SPAN class="token function">get_Value</SPAN><SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>theValue <SPAN class="operator token">==</SPAN> searchValue<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">yield</SPAN> <SPAN class="keyword token">return</SPAN> feature<SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Be aware to also release the features and the cursor when you´re done with them.
This would be how you verify the field type to be a text(string). Related samples are at the bottom. http://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#IField_Type.htm
Best of luck,
Jared
