If you want to find the best way to visit a set of locations, then you can turn on the "Reorder Stops to Find Optimal Route" option on the route analysis layer's properties (analysis tab). This capability is called the Traveling Salesman Problem.http://resources.arcgis.com/en/help/main/10.1/index.html#/Route_analysis/004700000045000000/To get good results, make sure to set the curb approach property of each stop (right side, etc) and also note that this will work well for a set of locations spread over some area. What is your application for the routes you are trying to generate?Jay Sandhu
