Thank you for the clarification!Running the Export to CAD tool with the aforementioned parameters but using the ESRI default seed file (template2d.dgn) produces a readable file, though my output units are meters regardless of the projection units specified in the input shapefile (Georgia State Plane West Feet). This makes sense, as the ESRI seed file is set to meters. I figured this could be remedied by creating a copy of the ESRI seed file and simply changing the working units to feet, and using this copy as the seed file in the Export to CAD tool. The result, however, is still an unreadable output file, even though the seed file used is a V8 dgn file.What am I missing?-Brandon
Hello,I am trying to export a shapefile of a few streams (polylines) as a DGN using the Export To CAD tool with the following parameters: Input Features: streams.shpOutputType: DGN_V8Output File: streams_output.dgnIgnore Paths in Tables: CheckedAppend to Existing Files: uncheckedSeed File: client provided dgn (V7) The seed file provided opens in Microstation Powerdraft XM fine, with the correct units shown (feet)The input shapefile is defined in State Plane Coordinates (Georgia West (feet))The tool runs with no errors, and the output file is readable in ArcMap (geometry and attribute table), however, I get an error when I attempt to open it in Microstation.Any thoughts? The way that Microstation handles coordinates is alien to me, and I am having difficulty troubleshooting this problem.-Brandon
