I've built a network dataset with street feature class and GTFS data.
To publish the network dataset as Network Analysis service, I followed the instructions of the guide and in particular the "Using your network dataset with ArcGIS Server".
When I published, a warning message with code 24066 "The network dataset uses a custom evaluator" is displayed.
Finally I published the Network Analysis service on ArcGIS Server.
The service works very well and when I load it on ArcMap the Find Route tool works perfectly.
But when I use the service from my Xamarin Android application and try to create a RouteTask, I catch this error:
Error: Esri.ArcGISRuntime.ArcGISRuntimeException: Internal error: Data type Unknown
I think that Transit Evaluator type is not recognised at run time.
The NAS uri is http://geoservizi.iuav.it:6080/arcgis/rest/services/network/network_gtfs/NAServer/Route
This is my work environment:
Windows 10 Pro (v. 1809)
Visual Studio 2017 Community with Xamarin
ArcGIS Runtime SDK for .Net (v. 100.5.0)
Xamarin.Android... library packages (v. 28.0.0.1)
ArcGIS Server 10.5
Can anyone help me?
Many thanks
Massimo
