Short answer: No.Essay form: ArcSDE isn't a database, it's an interface to databases. The only way to change table column order with the ArcSDE API is to export in the desired order and create a new table with the result. If, as in your example, you can coax the database to reorder the columns, then ArcSDE will present them in thatorder, but a brief web search indicates that SQL-Server, PostgreSQL and Oracle do not permit this as a trivial operation. Many of the referenced links recommendusing a view, which will work, but ArcGIS puts limits on geodatabase participationby views. If you're going to have to reload the table anyway, consider doing somerow-order optimization as well, by exporting in spatial index order.- V
