Hi All
I am doing query task using dojo and arcgis javscript,
but the result is not showing, there is no error, please help me, I am new to javascript
Hello Sadananachar,
I think that is because of the scope of function. first you need to use this._map and not just _map. Second you need to ensure that the scope of the fuction is at module level. this can be achieved by using lang.hitch. For query task it should be something like this.
queryTask.execute(query, lang.hitch(this, this.showResults));
Also in your case you need to ensure that the function where you are setting up the query (_onSubmitClick)is also in the same scope. But In your case it seems to be ok as you are already using this.showResults. If it is not working then you need to hitch it to the right scope as well.
Thejus
Hi thejus many many many many.... thanks to you, it solved my problem
Hi thejus
Actually i added a map instance like below but i am getting same error
Why all the changing the extents so many times? Before you go to the trouble of stepping through each resultFeature, I'd comment both the if loop and the for loop and make sure you're getting results returned at all. It could be you have results, but you have an issue with setting your extents. It's always possible you aren't on the right place in your map.
I'd also recommend checking your where clause at the rest endpoint and make sure you're getting data from there. Are you familiar with how to do this? If you navigate to the URL you have in the queryTask, scroll down to the bottom where it shows Supported Operations and choose Query.
At the top of that form, there is a place you can paste your where clause. Use actual values, not your variables, because this is a self contained kind of test. Be sure and set the outFields to *. Then run this, choosing either select GET or POST, I have found that it matters for this kind of test. If it doesn't return results successfully here, it won't work in your code either.
Can you please show me one sample example
Thank You
You need either keep the map variable as apart of Global, or when you initialize your module which contains the query, pass the map object as constructor parameter.
Hello Tim
Actually my main map is in another page, that is i am adding map in map.manager.js
and i am doing query task in another js module using dojo.
I debugged the code, here i am getting error like "unable to get 'map' and 'graphics' property which is undefined or null".
How to solve this issue, Please help me
Hello Sadanandachar,
The code seems to be ok. Are you getting any error? or the queryResults has Features?
Check the developer Tools and network activitiy and see if there were any issues.
Try the same query on the rest api, and make sure the where clause is formed correctly.
Hope this was helpful.
Hi Sadanandachar,
When you run the query in chrome, open your developer console, go to the Network tab, run the query in your map and then right-click the query in the network tab and choose "open link in new tab".
Now where it says "query?f=json" in your link, replace json with html
Now you can see if your query is working properly.
Hope this helps!
Tim
